blue smoking ???
Old Jan 7, 2002 | 01:36 AM
Cyber ITR's Avatar
Default blue smoking ???
my car blowing blue smoke , everytime i change gear
compression good , 210 in all 4
thanks
Old Jan 7, 2002 | 03:50 AM
MiraiZ's Avatar
Default Re: blue smoking ??? (VTEC_SiR)
is it just a puff of smoke when changing gears...or is it blowing smoke constantly???
Old Jan 7, 2002 | 12:27 PM
Cyber ITR's Avatar
Default Re: blue smoking ??? (MiraiZ)
just a puff of blue smoke , not much
whats wrong with it ?
Old Jan 7, 2002 | 12:39 PM
b18cTurbo's Avatar
oil ring by by
Old Jan 7, 2002 | 02:09 PM
Cyber ITR's Avatar
Default Re: blue smoking ??? (mikvtec)
oil ring or pistons ring ???
where about is the oil ring ?
Old Jan 7, 2002 | 02:28 PM
QuickHonda's Avatar
Oil ring is one of the 3 piston rings. It the bottom one and controls the oil on the cylinder walls. You change them all at the same time.
Old Jan 7, 2002 | 03:04 PM
porch's Avatar
New User
couldn't it just be a bad valve seal?
Old Jan 7, 2002 | 04:51 PM
rota426's Avatar
Default Re: blue smoking ??? (porch)
could be but prob oil rings...thats a gimme
Old Jan 7, 2002 | 05:10 PM
MiraiZ's Avatar
naa... if its just a puff, then I wouldn't worry too much...cars usually spit out puffs of smoke when changing gears...if its pouring out blue smoke and you can smell it even at idle or at a stop light...then you've got oil ring problems...but you should check it out just to be safe...
MiraiZ
Apr 2, 2013 07:51 AM
so-cal-em1
May 9, 2007 11:38 AM
B18cFreak
Apr 17, 2007 02:04 PM
T25So
Sep 8, 2004 11:39 AM
redteg1
Sep 19, 2002 04:29 PM
