how to make my downpipe cloosed loop
Old Jan 11, 2002 | 09:46 AM
Turbo_Teg's Avatar
New User
Default how to make my downpipe cloosed loop
yes i did a search and the only topic that came up was people discussing about cl and the power lost.can anyone tell me where i can find info in make one??
insruction or pic??
Old Jan 11, 2002 | 10:16 AM
brian b's Avatar
New User
Default Re: how to make my downpipe cloosed loop (Turbo_Teg)
its pretty simple.. find a way to pipe the wastegates output into your downpipe. theres lots of people saying how bad it is to do it close to the turbo and how much power you loose.. its hard to say whats the right way.. the f-max kit pipes it in the top of the elbow right off the turbo creating a vacuum when the wastegate is in use
basicly use your imagination
Old Jan 11, 2002 | 11:03 AM
RGAZ's Avatar
New User
You might want to check out the book, Maximum boost by Corky Bell. He explains the reason behind the downpipe closed loop really well. He also suggests that the wastegate should not connect to the exhaust pipe any closer than 18 inches from the turbo outlet. That is pretty far away. It has to do with the turbulence the wastegate causes on the turbo exhaust.
Go check out the book at barnes and noble.
Randy
turboorsupercharger
Jul 26, 2008 06:29 AM
4dek
Mar 8, 2008 10:39 PM
grnhatch94
Dec 11, 2005 07:23 AM
Dan_the_MaN
Oct 5, 2005 12:08 AM
B18PoweredCivic
Jul 4, 2004 06:30 PM
