PROBLEM ....please help
Old Jan 4, 2002 | 04:39 PM
LSturboHB's Avatar
Default PROBLEM ....please help
first my setup:
95 LS in a 92 dx HB. Custom setup, TDO4 turbo, Blitz BOV, Deltagate wastegate 7psi spring. 80psi of fuel using a cartech raising rate regulator, stock injectors, stock fuel pump. custom manifold, 2 1/2" downpipe, greddy SP exhaust, MSD 6A retarded ignition -1.
heres the deal ; when i get going the car surges, ( sputters, like a machine gun : dddd-dddd-dddd). fuel pressure stays at 80psi when surging like this. Could it be injectors sticking ? checked fuel filter- got as new one, all plugs are ok and firing.
compression good all across.
Today i tried to just push through the bogging/surging and it went through and boosted and held at only 5psi. (the deltagate is new and works), after it hit 5psi i held there for a little bit, and turned and got on it a little bit bogged out again, i pushed through it a little and let off and it backfired while i was pushing through the surging/bogging.
any info would be great.
my buddy has a 93 LS with the same problem and he has a brand new DRAG kit with inline 255lph pump.
Old Jan 4, 2002 | 04:48 PM
Ri5e's Avatar
Default Re: PROBLEM ....please help (LSturboHB)
Machine gun? Are you leaning?
If it runs smooth while under 3K and feels like its running on 3 cylinders when at 3K and up till 5K, then you feel a big surge, it could be a Bad O2 sensor. I had the same problem and found out my O2 sensor was dead.
Old Jan 4, 2002 | 05:39 PM
AlphaKennyWun's Avatar
Default Re: PROBLEM ....please help (BG Boost)
i would change the plugs even though you believe they are good.
Old Jan 4, 2002 | 06:21 PM
DLB1994's Avatar
Default Re: PROBLEM ....please help (SO3Burner)
yeh try new plugs
Old Jan 4, 2002 | 06:37 PM
LSturboHB's Avatar
Default Re: PROBLEM ....please help (DLB1994)
a set colder correct ?
what are other LS motorist using for there setup ? brand ?
Old Jan 4, 2002 | 07:45 PM
Mr. Vapor's Avatar
i have the same problem....plugs most likely......but your FMU COULD be stuck, thats my next opinion, look into that
Old Jan 4, 2002 | 08:58 PM
LSturboHB's Avatar
Default Re: PROBLEM ....please help (NYb16)
well fix the problem you have and lemmie know what it is , lol.
lsturbohb@aol.com
CavemanXXL
Jun 24, 2014 02:17 AM
dorado_mike
Oct 13, 2010 08:00 PM
Maxime
Jul 10, 2005 05:46 AM
Dutchie
May 7, 2002 11:50 PM
