BOV vacuum
Old Jan 6, 2002 | 07:23 PM
SlowB16's Avatar
Default BOV vacuum
I am going to be getting my turbo this next week and I need some help with the install. Here is the first question. What exactly is a vaccum line? I know it comes of the BOV, but where does it go to? Could somebody please help me out. And I am looking for a website that goes into detail about a turbo installation on a B16. Thanks
Old Jan 6, 2002 | 07:25 PM
SlowB16's Avatar
Default Re: BOV vacuum (SlowB16)
SO basically what I would like is a list of vaccum sources....
Old Jan 6, 2002 | 07:30 PM
JM Performance's Avatar
most of us use the fpr line. But you can also use the break booster line as long as its before the check valve. Of course you could aways tap new spots in the manifold, but who wants to do that.
Old Jan 6, 2002 | 07:35 PM
degradated's Avatar
New User
Default Re: BOV vacuum (00SilverLS)
Mine is teed into the FMU/fuel pressure regulator vacuum line, and so are my boost controller lines and boost gauge line. This seems to be the most obvious place to me for a vacuum source, but I'm sure there are plenty of other places.
Old Jan 6, 2002 | 07:48 PM
SlowB16's Avatar
Default Re: BOV vacuum (degradated)
Does anyone have any pics of this? So I will know for sure I am tapping into the right place('s)
Old Jan 7, 2002 | 12:15 PM
maxim's Avatar
The line from the fpr to the intake manifold seems so short to stick a bunch of tees in. My brake booster line is a lot larger than my fpr line and I am sure the kit comes with only tees for the fpr, where would I find a t that is large enough to fit in the brake booster line, but be small enough to fit the vacuum hose coming from the BOV?
Old Jan 7, 2002 | 12:23 PM
dbman96's Avatar
New User
Default Re: BOV vacuum (maxim)
Here's a thought... you could always just put ONE tee into the FPR line, and then add tees onto a new piece of vac. line for additional components.
Old Jan 7, 2002 | 12:35 PM
dustin's Avatar
I would look at an autoparts store.
http://rely.net/~dustin/sema/IMG_1839.JPG
Dustin
Old Jan 7, 2002 | 12:38 PM
maxim's Avatar
Default Re: BOV vacuum (dbman96)
I have seen numerous posts about the Greddy Type S not opening enough because of the lack of vacuum pressure. Therefore, I would prefer the larger diamater from the brake booster line, if it is in fact a better source for vacuum. So where do you get the proper tees to fit both the BOV hose and the brake booster line?
[EDIT] Thanks Dustin!! [EDIT]
[Modified by maxim, 3:40 PM 1/7/2002]
Old Jan 7, 2002 | 03:08 PM
FBP Ex-T's Avatar
can u just put a tee for the bov into the fpr line.....then connect the boost guage and what else? into the brake booster line??? btw where is the brake booster line?!
Old Jan 7, 2002 | 04:04 PM
HXMan's Avatar
Default Re: BOV vacuum (FBP Ex-T)
Brake booster hose is the big hose that connects to the brake booster. The brake booster is connected to your master cylinder.
seeeya04
Dec 1, 2005 06:40 AM
Andrew 825SM
Oct 24, 2002 07:15 PM
ceemarun
Jun 4, 2002 06:33 PM
Nfurno
Apr 2, 2002 04:25 PM
SagaGSR
Sep 19, 2001 06:50 AM
