f-max - does the wastegate need a boost source or vaccum/boost source
Old Jan 10, 2002 | 08:30 PM
Brian_92GSR's Avatar
New User
Default f-max - does the wastegate need a boost source or vaccum/boost source
Does the wastegate, boostcontrooler (AVC-R), and blowoff valve need a boost source or a vaccum/boost source?
Old Jan 10, 2002 | 09:03 PM
supergreenNA1's Avatar
New User
Default Re: f-max - does the wastegate need a boost source or vaccum/boost source (Brian_92GSR)
bov... boost/vacuum from intake manifold.
wastegate... boost only from turbo compressor.
avc-r... that's a little too complicated to explain here. read your instructions. if you don't have them u can download them from the internet.
Old Jan 10, 2002 | 09:19 PM
D-SPEED's Avatar
Default Re: f-max - does the wastegate need a boost source or vaccum/boost source (supergreenSol)
it can go a number of different ways..
-BOV must be hooked up to vacuum/boost post throttle plate
-WG can actually be hooked up pretty much anywhere...on the compressor, on the charge pipe, or even to the manifold that has vacuum/boost.
i plan on hooking mine up to the charge pipe right before the throttle plate, as the directions for the tial say.
elpiar
Mar 21, 2005 09:09 PM
FOrSfEd
May 17, 2004 10:13 PM
99silverbullet
Jan 3, 2004 06:28 PM
pissedoffsol
Oct 19, 2003 09:37 AM
Cowboy
Jun 16, 2003 02:12 PM
