DTA standalone....
Old Jan 10, 2002 | 09:10 PM
meanteg's Avatar
New User
Default DTA standalone....
Someone is using it ? any comments would be appreciated, good or bad.
http://www.dtafast.co.uk/index.htm
Old Jan 11, 2002 | 02:47 AM
forcefed's Avatar
Default Re: DTA standalone.... (meanteg)
i know TRD has tried them, anyone else????????????
Old Jan 11, 2002 | 03:35 AM
Tapp's Avatar
New User
I just installed the P8 pro system in my hybrid civic. It's and exellent system with featues that compare to the motec, but the cam trigger can be a problem if you want to run full sequential.
Old Jan 11, 2002 | 08:46 AM
bigTom's Avatar
Default Re: DTA standalone.... (Tapp)
what manifold is that? it looks just like the kooks manifold except is comes out a little further
Old Jan 11, 2002 | 12:05 PM
Tapp's Avatar
New User
Default Re: DTA standalone.... (Tom)
It's a manifold I made. 321 stainless.
Old Jan 11, 2002 | 06:19 PM
meanteg's Avatar
New User
Tapp, can i ask you why cou chose the p8Pro over the E48 EXP ? I'm trying to determine wich one would best fit my needs... My GSR is daily driven and it will see 20 psi at the drag strip.
"Turbo pressure control with overboost protection."
Does that mean they have an integrated boost controller?
[Modified by meanteg, 3:20 AM 1/12/2002]
[Modified by meanteg, 8:30 AM 1/13/2002]
Old Jan 12, 2002 | 06:45 AM
Tapp's Avatar
New User
I chose the P8 because I wanted the ability to adjust timing and fuel for each cylinder individually, but the e48 would probably be fine for what you want to do. yes it can control boost, and it has overboost protection you can set to whatever you want. It will cut spark and fuel when it hits whatever manifold pressure you enter. it can also do launch control and traction control but I havent tried those features yet. I you go with the E48 you dont have to worry about a cam sensor, but you will need a crank trigger.
Old Jan 12, 2002 | 11:30 PM
meanteg's Avatar
New User
Thanks, and btw, you got a really nice setup!
[Modified by meanteg, 8:31 AM 1/13/2002]
98_4drCivic
May 5, 2005 08:12 PM
Alberto
Jan 10, 2004 12:40 PM
RedStarGsr
Oct 14, 2003 10:56 PM
TurBoTeG
Oct 31, 2001 11:55 PM
