Raising compression ratio and Turbo??
Old Jan 6, 2002 | 12:54 PM
Adampops's Avatar
Default Raising compression ratio and Turbo??
If i am only goin to be boostin about 8psi. Then is it okay for me to upgrade my pistons to some 10.0:1??? I have a stock RS right now. I was just wondering cuz i dont really wanna boost higher than 8psi, but i wanna squeeze every ounce of power out of the engine.
Old Jan 6, 2002 | 01:49 PM
MiraiZ's Avatar
Default Re: Raising compression ratio and Turbo?? (Adampops)
with high occtane fuel (91, 92+) and maybe a J&S to be safe, you should be okay....but with lower CR, you can boost higher...
Old Jan 6, 2002 | 02:54 PM
DIRep972's Avatar
Smarter than you
where are u gonna benifit from running higher compression?.. only on the bottem end, it will give u a little more torque and a quiker spool up.. top end would benifit more by lowering compression but at the same time adding more boost..
9.5:1 is a happy medium, youll get a lil more torque and quiker spool up but you will still be able to run plenty of boost for a street car..
[Modified by DIRep972, 11:56 PM 1/6/2002]
Old Jan 6, 2002 | 06:38 PM
adam's Avatar
you'll be fine, just tune it well. i am still running the stock usdm type R CR of 10.6:1 on my stock block at 8psi and it is lots of fun
Old Jan 6, 2002 | 09:34 PM
DIRep972's Avatar
Smarter than you
Default Re: Raising compression ratio and Turbo?? (adam)
what are you using to tune it?
Old Jan 6, 2002 | 10:56 PM
BoostinDC2's Avatar
exactly just fine some one who knows how to tune.
Old Jan 7, 2002 | 06:16 AM
PROFILES2000's Avatar
Default Re: Raising compression ratio and Turbo?? (BoostinDC2)
heres my 10.0-1 compression pistons JE's
Old Jan 7, 2002 | 08:44 AM
adam's Avatar
Default Re: Raising compression ratio and Turbo?? (DIRep972)
i am running a hondata right now, not even fully tuned yet, just running a base program written by sgT for my car
Old Jan 7, 2002 | 10:15 AM
dustin's Avatar
JE does not make shelf pistons in 10.0:1, but you can have them custom made. They do have 9.8:1 GSR pistons on the shelf though.
I have JE 9.8:1 pistons for the GSR. I am thinking of ordering a set of these same pistons to drop into my LS. (I think I will net around 9.5:1 with them)
Dustin
99siRACER
Jan 3, 2012 12:20 AM
crxhybrid1320
Mar 17, 2010 02:44 PM
imzjustplayin
Dec 27, 2009 12:46 PM
92civtegra
Aug 15, 2007 08:26 PM
RooskiGSR
Feb 28, 2005 04:23 PM
