For turbo experts
Old Jan 8, 2002 | 06:44 PM
Turbo_Teg's Avatar
New User
Default For turbo experts
ok my friend gave me a wastegate but the spring is 25 lbs,can i use the wastegate with a boost contoll to lower the boost rate to 7lbs or i can t because the spring rate is to high.
pls dont flame i you cant understand it
Old Jan 8, 2002 | 06:45 PM
brian b's Avatar
New User
Default Re: For turbo experts (Turbo_Teg)
you have to get a lower spring.. the spring controls the minimum pressure the w/g will open at
Old Jan 8, 2002 | 06:55 PM
Turbo_Teg's Avatar
New User
Default Re: For turbo experts (brian b)
yea thats wat figured,so if i have a 9lbs spring wats th lowest and highest amount of boost the spring can handle
Old Jan 8, 2002 | 06:57 PM
Ben Huynh's Avatar
The lowest amount of boost will be 9psi. The highest amount of boost will depend on which wastegate you have.
Old Jan 11, 2002 | 09:16 AM
Turbo_Teg's Avatar
New User
Default Re: For turbo experts (ben@importparts.com)
so ben how much would it be if i ned a 7psi spring for my hks wastegate and i need a flange to connest it to mymanifold too
Old Jan 11, 2002 | 02:21 PM
smoothludey2's Avatar
New User
WHAT?? i thought the spring on the wastegate dictated the max amount of boost not the minimum.....so if i get a boost controller to boost less than the spring i need to get a new spring?
Old Jan 11, 2002 | 02:58 PM
TurboSedan's Avatar
New User
Default Re: For turbo experts (smoothludey2)
Yep, the spring dictates the MINIMUM boost amount of the wastegate. If you want to boost lower than the spring rating, you have to get a new softer spring. Peace.
Old Jan 11, 2002 | 03:58 PM
97accordex's Avatar
Default Re: For turbo experts (97CivicFerio)
So why bother with a spring?
Old Jan 11, 2002 | 06:17 PM
TurboSedan's Avatar
New User
Default Re: For turbo experts (97accordex)
Because he already has the friggen wastegate! What? You want him to buy a whole new wastegate? Now that would be foolish!
Old Jan 11, 2002 | 06:25 PM
SEFIxCivic's Avatar
Well, when you start boosting high 20-30 psi. running a low psi spring will have more boost fluctuations. You can't really tell by the naked eye, but with data logging you can tell.
Old Jan 14, 2002 | 07:35 PM
New User
Default Re: For turbo experts (SEFI8LOxCivic)
ok, say i want to boost 9 pounds max....but i want to boost 6 pounds most of the time....i have a boost controller....now should i just get the 6 pound spring?
VTi_b0i
Jun 3, 2009 01:50 AM
powerdbygarrett
Jul 3, 2008 01:50 PM
TurboCoop
May 19, 2004 12:21 PM
gdrum
Feb 24, 2004 01:55 PM
Cyber ITR
Jan 19, 2004 03:38 AM
