Best Pistons for Nitrous?
Old Jan 6, 2002 | 08:02 PM
Endless's Avatar
Default Best Pistons for Nitrous?
This may be a dumb question, but are there pistons that are made specifically for nitrous? If so, what are the best ones? Thanks.
Old Jan 7, 2002 | 08:54 AM
delacampos's Avatar
Default Re: Best Pistons for Nitrous? (Endless)
i know of no nitrous specific pistons. what kind of car do you drive? how big of a shot do you plan on running?
Old Jan 7, 2002 | 10:05 AM
Endless's Avatar
it's going to be a b20z with a 150 shot or so
Old Jan 7, 2002 | 11:32 AM
civicsidude's Avatar
New User
nitrous loves high compression,, but you can go to high with it,, i recommend je pistions and eagle rods,,
the highest compression i would run is 11:1 but i would not take it to a 150 with out breaking in the motor first with the lowest direct 80 shot,, if you plan on running anything over a 75 shot then go direct it is alot safer
if you have anymore questions you can send them to me i mod the nitrous forum on csi but i frequent this board
Old Jan 7, 2002 | 12:00 PM
Endless's Avatar
Default Re: Best Pistons for Nitrous? (civicsidude)
My setup is going to be a b20z, JE or Endyn pistons (11:1), eagle rods, JG cams, and some other stuff. I've had some friend blow engines by rushing through the break in so I won't be spraying for the first 2k miles
Old Jan 7, 2002 | 12:46 PM
b18cTurbo's Avatar
for a 150 direct port i would put some je 10.1 compression piston rods and a must ignition upgrade for less detonation !fuel pump ,clutch,exaust 2.5,whit kamikaze headers
tempsohc
15
Mar 11, 2011 06:08 PM
Dr.Honda
Apr 19, 2007 12:29 AM
I_eat_Rice
Sep 21, 2006 09:20 AM
shazbot
40
Oct 5, 2004 10:15 AM
Pinhead
Feb 3, 2002 09:26 AM
