Fuel upgrade for f-max kit?
i am currnently running an fmax kit with the mf2 and extra injectors on an f22 accord motor and need to upgrade my fuel. i am planning on an in tank fuel pump and rising rate fpr... which ones should i use and what else should i do i already detonated a grip and blew up the motor and dont want to do it again opions and recomendations are appreciated
Re: Fuel upgrade for f-max kit? (cl4show)
unless you want to try and run the same setup. you can sell the MF2, ++injectors.
New User
wow, you blew up your motor cuz you didn't have it tuned? damn bro...anyways, get a true standalone if you have the money, get a new fuel rail, fpr, intank pump, and larger injectors....basically get rid of mf2...most tuners don't like that setup anyway.
Re: Fuel upgrade for f-max kit? (smoothludey2)
um...most "people" dont like that setup. many tuners (well, people who have their MF2 tuned ) say it works great
-Matt (still backing up the MF2 at all costs
Re: Fuel upgrade for f-max kit? (00SilverLS)
so if i did decide to keep the mf2 and tune it what else should i do, good for around 10psi, in tank feul pump and a fpr will this be ok i would also get feul pressure gauge and maybe a air feul ratio gauge to monitor things
Texas B*tch!
Re: Fuel upgrade for f-max kit? (BlueShadow)
Well to get a standalone on a f22 engine you have to switch the ECU's to like a LS non-vtec or something for the Hondata b/c they couldn't decode 96+(OBDII)
So unless the AEM will work, then I think any Accords w/ the OBDII are screwed, that could be why he didn't get a standalone.
EDIT: Btw, recommend getting the Vortech FMU to go w/ your injectors and fuel pump. Depending on the size of your injectors, if they are like 310cc probably get the 8:1 Disk.
[Modified by ForcedAccord, 1:09 AM 1/11/2002]
New User
The mf2 setup for the f-max kit using the lucas injectors before the intake manifold is a really ghetto setup....what it is is an alternative setup if you can't afford or get your hands on a standalone. The mf2 will get you up and running...but if you ask anyone who knows anything they'll take a standalone system over mf2 anyday.
Re: Fuel upgrade for f-max kit? (ForcedAccord)
ow if you are talking about a Hondata though you are correct, you have to replace your OBD 2 ECU with an OBD 1 ECU. Last I heard no one has been able to reprogram andy OBD 2 ECU.
There's more to tuning than A/F ratio.
Consider the J&S Ultra SafeGuard V.2.
It has knock retard, boost retard, and an electronic MAP limiter. Importparts.com has units in stock.
I'm surprised Jhame at F-Max didn't recommend it when you bought your kit.
well with the OBD 2 --> OBD 1 swap you have get the OBD 1 ECU, resistor box and I think the correct peak and hold injectors. I cant remember exactly what is needed for the swap.
here's a thread with some good info on how a Haltech works
http://www.preludeonline.com/showthr...threadid=37326
http://www.preludeonline.com/showthr...threadid=38174
New User
if you are doing the obd2 -> obd1 swap for hondata you can keep the saturated injectors if you want, if you want peak and hold then yes, you need the resistor box. I heard the haltech install is very difficult and it's rare to find someone to install it for you without charging an arm and a leg.
ja20_eg
Engine Management and Tuning
09-19-2012 11:14 AM
jeremy.
09-29-2003 05:35 PM
