f-max installation - part two
Old Jan 10, 2002 | 12:17 PM
Brian_92GSR's Avatar
New User
Default f-max installation - part two
I've pretty much gotten everything done except for the oil system. I'm not really positive on where the oil pressure switch is. And how exactly are you supposed to use the pipe taps supplised by f-max. Are they supposed to be turned slowly or quickly? And does the oil feed line have to be run very carefully to get it to reach? That's what it seems like on mine.
Old Jan 10, 2002 | 12:25 PM
JM Performance's Avatar
Default Re: f-max installation - part two (Brian_92GSR)
Heres a pic of the oil pressure switch (its the blue thing): (thanks dustin)
You need a 15/16" deep socket to get it out.
Also, to tap it out just make sure the tap stays strait. But what I opted to do was use the Z10 converter fitting. That way I dont have to tap my block.
[Modified by 00SilverLS, 4:25 PM 1/10/2002]
jens0771
10
Apr 20, 2014 06:20 PM
gtcali
Feb 11, 2003 12:26 PM
jthelman
Sep 9, 2002 05:43 PM
pelotudo
Aug 18, 2002 06:31 PM
