LS final drive in a S4 tranny? (2000 Civic Si)
Will it work?
Have a quaife diff for the s4 tranny and want to keep it but don't know if the final drive will bolt up.
Re: LS final drive in a S4 tranny? (BlwnBlue)
Why don't you just get in touch with Tyrone? Or are you planning on doing this yourself? Perhaps check out the hybrid board, or for that matter the Integra R forum on here has plenty of tranny part swapping fiends on there.
everyone always confuses this, the LS and b16a trannies all have 4.4 final drive, changing is useless.
greg
greg
Re: LS final drive in a S4 tranny? (vtec4gs)
From what I understand the 2000 LS has a 4.2 final drive..I had heard this before but finding answers took a while but I've checked several websites..and all have the new LS w/ a 4.2xx final drive..Do they have wrong info? 5-Speed Manual
2000 LS
Transmission Ratios (:1)
1st 3.230
2nd 1.900
3rd 1.269
4th 0.966
5th 0.714
Reverse 3.000
Final Drive 4.266
[Modified by BlwnBlue, 8:10 AM 1/9/2002]
2000 LS
1st 3.230
2nd 1.900
3rd 1.269
4th 0.966
5th 0.714
Reverse 3.000
Final Drive 4.266
but the 99+ si has the 4.26 also.
http://tiiite.b16a.com/Bgears.htm
Re: LS final drive in a S4 tranny? (DragII)
http://www.consumerguide.com/index.c...5263style41820
http://www.caranddriver.com/xp/Caran...lass=42&page=4
both show the final drive as being 4.40..
**** I hate conflicting info..anyone know For SURE?
I am assuming that they will look different when placed on top of eachother(provided they aren't the same)...will the spines be closer or farther apart?
will they be at a harder angle? Are they stamped?...I'm going to pull the tranny apart this weekend to replace the diff ...and while I am in there I can compare the two...
they all have 66 teeth on ring gear and 15 teeth on mainshaft ... that 4.40 ratio ... I rebuild trannies all the time.
greg
greg
And if anybody has been around its vtec4gs. Everytime I had a question when I was younger I would always look to him for answers, and I can assure you he is right 99.999999% of the time.
art
art
Re: LS final drive in a S4 tranny? (Arturbo)
OMG!...A real answer....Much thanks...
So it's a 4.40 final drive!
Can you help w/ my second question..Will it fit in the casing and bolt up to the diff?
BTW the only place I found that stated the Si had a 4.26 final drive was on the Titeboy(sp) racing site someone posted up earlier...even in the captions it states that someone physically pulled it apart and counted the splines and said it is a 4.40 final drive.. only reason they posted it as having a 4.26 was because the helms manual said so..but they said the helms was printed incorrectly..
Both my Helms manual and 1998 factory manual state that B18B1 engines have a 4.266 FD. All the information I have seen says that B18Cx and B16A2 have 4.400 FDs.
crazy_eddy
06-05-2008 11:31 PM
VSM3point5genDC4
10-23-2003 09:11 PM
