Slick tire sizes
Old Jan 6, 2002 | 01:56 AM
Hispeed's Avatar
Default Slick tire sizes
I need to hear about real world experiences from people that have tried 22x8x15 and 24.5x8x13 slicks. I have been using the 22" so far and have been able to muster a 12.21 @115.31 w/ a 1.9 60', but I am wondering if I went with the 24.5 if my et's would drop?? I would think that the 22's make me accelerate faster out of the hole, but I am wondering what you think will happen or what you have expereinced when you changed sizes. Thanks.
Old Jan 6, 2002 | 02:49 AM
paulzy's Avatar
Default Re: Slick tire sizes (GSRev)
I'm wondering also...if I'm making 400whp, should I be fine with 22" or go straight to 24's....
Old Jan 6, 2002 | 06:04 AM
b18bturbo's Avatar
Default Re: Slick tire sizes (Slow_ass_4dr)
go straight to the 24s you will be much happier. make sure you are putting out adequate pwr though to get you out of the hole after that it really just making sure you stay in good groove and you should beokay.
Old Jan 6, 2002 | 12:54 PM
earl's Avatar
I run 22' tall tires and have gone 10.25 with a couple of 1.5's and a bunch of 1.6 60' times. This is done with a peg leg LS tranny and turbo GSR engine. Have not broken an axle or tranny yet. 22 tall seems to be easy on parts
Old Jan 6, 2002 | 12:55 PM
11secdx's Avatar
GSRev- what kind of 1/8 times are with that 12.21? my friends gsr hatch, on 10 psi and 22x9x13 MH, put down 1.72 60'.
Old Jan 6, 2002 | 02:02 PM
jinxproof99's Avatar
New User
Default Re: Slick tire sizes (b18bturbo)
i agree. if your making anything over 310 to 320 to the wheels, go with the 24's. making 375 or more and go with 25's. 450 or more...go with 26's......just my experience/opinion.
Old Jan 6, 2002 | 02:04 PM
paulzy's Avatar
Default Re: Slick tire sizes (earl)
they have different 22" tires? I thought that 22" is 22"...the width doesn't really make a difference with the height....
Old Jan 6, 2002 | 02:20 PM
New User
better width means more contact patch and better traction.
Old Jan 6, 2002 | 02:39 PM
DLB1994's Avatar
Default Re: Slick tire sizes (jinxproof99)
this year am going to be running 26-8-15 M/T hope i dont hurt nothing
Old Jan 6, 2002 | 03:01 PM
New User
Default Re: Slick tire sizes (DLB1994)
on your accord????????????
Old Jan 6, 2002 | 03:09 PM
DLB1994's Avatar
yeh the accord
my civic don't got enough ***** for slicks that big (b16) cant get out of its own way into it getting in vtec i have to run some of them 14-5-13M/T on there
Old Jan 6, 2002 | 03:10 PM
New User
are you cutting the wheel well???
Old Jan 6, 2002 | 03:14 PM
DLB1994's Avatar
i dont think i have to i got 225-35-19 under there now the wheels are 8inch
and no rub at all but ill find out soon i been looking at 27's to
Old Jan 6, 2002 | 07:02 PM
earl's Avatar
I use 9 1/2" wides and run as low as 6 lbs for the largest patch possible on 22" talls.
Old Jan 6, 2002 | 07:27 PM
Adi Radoncic's Avatar
On Fire!
Jinxproof, have you had any problems breaking parts with that combination your running??
Old Jan 7, 2002 | 10:52 PM
paulzy's Avatar
Default Re: Slick tire sizes (newgsr)
yeah, I know that more width equals a larger contact patch, but i didn't know that they had different heights for 22" slicks...
Old Jan 8, 2002 | 12:06 AM
sparkz's Avatar
I've hit a best of 1.72 on 22x8x15 MT's. 1.8's are the norms and occasionaly mid to high 1.7's.
Old Jan 8, 2002 | 05:28 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Slick tire sizes (sparkz)
sparkz, what setup are you running??
Engine/poweraddy/tire psi
I've never been able to get 22x8x15 to hook, even at 11 psi.
My 20x8x14's hook ggod enough for 1.87 from a juiced SOHC.
I might goto 22x8x14 later in season.
Old Jan 8, 2002 | 05:53 AM
b18bturbo's Avatar
Default Re: Slick tire sizes (Mista Bone)
its all about how you launch depening on rpm vs your track conditions. I launch on the 2step at different rpms depending on my traction. Each track you run at will give you different results. The best way to determine your maximum traction is practice at the track at a given time. Each time you make a pass jot it down on your log book and put exactly what tire combo + pressure etc and also make sure you jot down the temp. I have noticed in extreme heat compared to mild weather there is big difference in traction. Also after you do that trie a different combination with tire pressure and rpm launch. Each time you should get better and not worse.
To be consisten is the key. Cutting 1.5-1.4 60ft are not that difficult if you just practice and have good launches coming out of the hole. It all about how you get your power to the ground in the fastest possible manner.
Old Jan 8, 2002 | 10:47 AM
New User
i launch at 7000 rpm's w/ 25x8x13's @ 8 psi. i have never broken an axle or dif.
ashb82
Aug 27, 2011 06:06 PM
pip9
Nov 17, 2004 02:17 PM
saso
Dec 10, 2003 08:35 PM
99lspwr
Jul 1, 2003 05:19 AM
g2turbo
Jan 15, 2003 01:00 PM
