running hondata off base maps only!
Old Jan 7, 2002 | 10:00 PM
DIRep972's Avatar
Smarter than you
Default running hondata off base maps only!
im going to be getting hondata 2b and 440cc injectors very soon.. Im planning on running 7-11psi on my Revhard LS with it.. problem is is I cant afford to have it seriously tuned yet.. Is it ok to run off the base maps for a few months? can i run that and just keep boost below 9 or will i be fine running 11 on a good base map? or should I just wait altogether to install it until i can afford to really dyno tune it..
I figure hondata with a good basemap is much better then the FMU high fuel pressure set up so at least if i keep it under 9 ill b ok..
[Modified by DIRep972, 7:03 AM 1/8/2002]
Old Jan 7, 2002 | 10:45 PM
VaporTrail's Avatar
New User
Default Re: running hondata off base maps only! (DIRep972)
the base maps are ok to drive on, not to race on. Most I've used are pretty far off.
Old Jan 8, 2002 | 05:53 AM
HXMan's Avatar
I would think this as well. A FMU to me sounds like a really half assed way to control fuel delivery.
Old Jan 8, 2002 | 06:54 AM
Seraph0's Avatar
I plan to do the same thing when I can afford it Chris.
Run a Hondata with 440s and the base map.
I don't know if I can justify the 4b, but I really want it! Just so much $$... ack!
Old Jan 8, 2002 | 07:30 AM
dust's Avatar
Default Re: running hondata off base maps only! (MarkC)
4b here in Austin. I've yet to get it installed an play with it, but at least it's here.
Old Jan 8, 2002 | 08:16 AM
TurboTypeR98's Avatar
New User
who's going to tune it for you? Is there a Hondata tuner in the Dallas area?
Old Jan 8, 2002 | 08:56 AM
Xerxes's Avatar
New User
Default Re: running hondata off base maps only! (TurboTypeR98)
It depends on who makes your base map.. I got my base map for Tom Payn for a 99 Civic Si, using a p28 ECU. With 47psi of static fuel pressure things looked good at low boost but once i got up to 8psi at the dyno, the base map started to get too lean (ilke 12-13:1 a/f ratio)
I wouldn't push more than 7-8psi on an untuned base map unless you want to pump up the base fuel pressures somewhat to compensate. If you turn up the pressures though, you may have problems with cold idling.
-Xerxes
Old Jan 8, 2002 | 09:15 AM
TurboSedan's Avatar
New User
Default Re: running hondata off base maps only! (Xerxes)
The base map crapped out at 8Psi? That seems low to me. I plan on using the P28 ECU on my 97 EX with the Hondata 2B from Tom Payne. I will have to mention to him that 8Psi is not going to be enough, I need to hit 12-14 Psi safely.
Old Jan 8, 2002 | 10:25 AM
prospeed's Avatar
The base program is meant to get you to your target as close as possible and to get you started. When i give you the base program it will be close. Good for 9lbs. Anything over that you will need to dail it in on the dyno. Oh alot better then a FMU!
Old Jan 8, 2002 | 11:13 AM
Arturbo's Avatar
Better than steak
25 Year Member
cough cough, maybe..
Old Jan 8, 2002 | 11:16 AM
lucas569's Avatar
from what ive read the base maps are pretty close and only need "fine tuning".
at 1st when hondata 1st came out there werent many maps to choose from, but if you tell them your setup,turbo size,compression,cams,etc..theyll pick a base program thats pretty close.
Old Jan 8, 2002 | 01:09 PM
TurboSedan's Avatar
New User
Default Re: running hondata off base maps only! (lucas569)
Awesome!
Old Jan 8, 2002 | 06:45 PM
prospeed's Avatar
Default Re: running hondata off base maps only! (RealTegGirl)
Just waiting for art to get the 4b so i can hook u guys up!! hehe I might just have to fly out there to Dallas to tune your cars! Hit me up when u get the chance!
Old Jan 8, 2002 | 07:45 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: running hondata off base maps only! (prospeed)
Well I took the fist step to getting closer to hondata, I bought a lap top today. Now my next goal is the dyno, then Hondata..
art
Old Jan 8, 2002 | 08:14 PM
DamonBoost's Avatar
New User
Default Re: running hondata off base maps only! (Arturbo)
IF I wasnt fixing to rebuild Art I would seriously consider giving you my Hondata 4b in exchange for you buying me a 3B w/ datalogging and getting me dyno time and tuning it. That sound interesting to you? If you still dont have it when I get rebuilt, we will talk bro..
Old Jan 8, 2002 | 08:50 PM
prospeed's Avatar
Sounds good just let Tricia know when you are ready!
Old Sep 29, 2004 | 09:12 AM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">im going to be getting hondata 2b and 440cc injectors very soon.. Im planning on running 7-11psi on my Revhard LS with it.. problem is is I cant afford to have it seriously tuned yet.. Is it ok to run off the base maps for a few months? can i run that and just keep boost below 9 or will i be fine running 11 on a good base map? or should I just wait altogether to install it until i can afford to really dyno tune it..
[Modified by DIRep972, 7:03 AM 1/8/2002]</TD></TR></TABLE>
its cool, boost away!
Old Sep 29, 2004 | 09:46 AM
per4mance's Avatar
I would'nt run it hard on a base map, I have got an ls/vtec turbo with some 450's in it on the base map it ran way to lean bad detonation on any boost above vtec, but for part throttle it will be ok still alittle lean but not enough to hurt anything, know matter what you need to tune it, turbo motors aren't cheap so becareful with the basemap.
Old Sep 29, 2004 | 09:49 AM
Finest's Avatar
Default Re: running hondata off base maps only! (per4mance)
Are you using DSM 450's with Hondata?
Old Sep 29, 2004 | 10:46 AM
espanol's Avatar
Default Re: running hondata off base maps only! (Finest)
so chris, did you ever get that hondata...??did art ever get that dyno??
donkiman's Avatar
at the shops around here they really advise against it. one guy blew his headgasket after 350 miles and 1 guy after 700 miles. fact is when u start driving your boosted car your not gonna be able to just tell yourself to stay out of boost. I personally didnt drive mine until i had enough cash to get it tuned, but if thats not an option i would say just stay out of boost until u get it tuned.
Old Sep 29, 2004 | 10:49 AM
espanol's Avatar
Default Re: running hondata off base maps only! (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote">at the shops around here they really advise against it. one guy blew his headgasket after 350 miles and 1 guy after 700 miles. fact is when u start driving your boosted car your not gonna be able to just tell yourself to stay out of boost. I personally didnt drive mine until i had enough cash to get it tuned, but if thats not an option i would say just stay out of boost until u get it tuned.</TD></TR></TABLE>
wow, i hope direp takes that into serious consideration.
Old Sep 29, 2004 | 10:52 AM
Finest's Avatar
Default Re: running hondata off base maps only! (espanol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espanol &raquo;</TD></TR><TR><TD CLASS="quote">
wow, i hope direp takes that into serious consideration. </TD></TR></TABLE>
heh heh
1.8EG-T
Dec 28, 2003 09:49 AM
ID_ten_T
Jul 12, 2003 09:19 PM
g2turbo
Nov 23, 2002 06:00 AM
HXMan
Dec 24, 2001 11:52 AM
