what do you guys do about crankcase ventilation?
I recently took my head off and cleaned the itake manifold and much to my disgust it looked like oil was getting pulled in from the breather line on the valve cover down through the turbo and fed back into the manifold.
I have the breather line running to the intake piping right behind the filter.
Does anybody have any suggestions? Should I run a "trap" of some sort on the line? What about one of those cute little filters?
New User
Re: what do you guys do about crankcase ventilation? (glagola1)
if you are indeed getting oil from your valve cover breather, you have serious problems. Now, if you're getting oil from the PCV line, that's when you'd use a catch can.
Re: what do you guys do about crankcase ventilation? (VaporTrail)
I don't think that excess pressure in the head is causing the oil to migrate. I think that when 7600 rpms of flying valves is splashing oil around and a majorly hungry turbo is creating vacum in the line that opens up next to splashing oil is when the oil moves down the line.
I am going to try one of those little breathers first.
This one topic really caught my interest. It seems that no one is really running an adequate setup. I want something that will always (under vacuum, atmosphere and boost) pull out crankcase
vapors and pull in fresh air, and without the aid of any pumps.
Can I make the exhaust create a vacuum? If I use a tube going into it at a very heavy angle? If I do this, couldn't I have that pull out my vapors and pull in fresh air from a valve cover breather filter?
I've been thinking about this topic for a while now, and am getting frustraited with it. It seems that nothing so far is good enough.
New User
Re: what do you guys do about crankcase ventilation? (00SilverLS)
simple link that will cover all of your needs
http://www.theoldone.com/components/breather/
