only use NGK plugs.
Old Jan 11, 2002 | 02:35 PM
Full-Race Geoff's Avatar
Default only use NGK plugs.
I recently learned the hard way as did another friend, on the same exact day. Dont use either Denso iridum nor Zex turbo/nitrous plugs (they are actually made by champion)
please heed my advice if you love your engine.
Old Jan 11, 2002 | 02:57 PM
TurboSedan's Avatar
New User
Default Re: only use NGK plugs. (FFgeoff)
Thanx for the heads up Geoff!!!!!
Old Jan 11, 2002 | 03:25 PM
ImprtTunr's Avatar
Default Re: only use NGK plugs. (97CivicFerio)
Details??? What happened?
Old Jan 11, 2002 | 03:30 PM
DIRep972's Avatar
Smarter than you
what happened man?
Old Jan 11, 2002 | 03:31 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: only use NGK plugs. (DIRep972)
Geoff, I already knew this because viren told me the same thing a while back. I didnt believe him untill he showed me some results.
art
Old Jan 11, 2002 | 04:48 PM
ImprtTunr's Avatar
Default Re: only use NGK plugs. (Arturbo)
C'mon guys give us some information on what youre talking about. I ordered some of these plugs and want to know what the deal is cause if i shouldnt use em I wanna know why.
Old Jan 11, 2002 | 04:49 PM
98Psi ITR's Avatar
Default Re: only use NGK plugs. (ImprtTunr)
What's the deal with Denso iridium's?
Old Jan 11, 2002 | 04:57 PM
b18bturbo's Avatar
Default Re: only use NGK plugs. (98Psi ITR)
Beleive me when i say do not use the irdium denso or ZEX turbo/nitrous plugs in your rides. They are scrap compared to std NGK plugs.
I have tested alot of things during my racing seasons and i can verify that they indeed will blow up **** inside your motor at high rpms. I have seen it done in person. They jsut start to fail at high EGT and high rpms loads.
Old Jan 11, 2002 | 05:15 PM
ImprtTunr's Avatar
Default Re: only use NGK plugs. (b18bturbo)
Ok well which NGKs do I need to get for my 2000 Integra LS thats going to be equipped with 55 shot zex nitrous and what do I need to gap them at?
Old Jan 11, 2002 | 05:28 PM
b18bturbo's Avatar
bcpr6es11 or bcpr7es11 gapped at .036
Old Jan 11, 2002 | 05:36 PM
ImprtTunr's Avatar
i think most people use the 7s, is that what I should go with?
Old Jan 11, 2002 | 05:42 PM
b18bturbo's Avatar
usually for every 50 shot i would go 1 step colder from the factory. the 7s would be fine i would also reccommend retard timing by couple of degress
Old Jan 11, 2002 | 05:59 PM
LSturboHB's Avatar
NGK's ehhh
gotta go with BOSCH dual prongs
Old Jan 11, 2002 | 06:02 PM
TurboSedan's Avatar
New User
Default Re: only use NGK plugs. (LSturboHB)
The 6 means one step colder, 7 is two steps colder! Go with the 7's if you run +50HP over stock or more.
Old Jan 12, 2002 | 04:08 AM
boosted3g's Avatar
What about the NGK Iridiums? If they suck also does NGK at least make a plug that is 3 or 4 steps colder. My last run of the season i cranked the boost up a little bit higher than normal and the plug (Autolite 3942 gapped at .32) evaporated. No detonation or high egt's the whole tip it just disappeared. Any suggestions on what plug for my new motor 2.0 LS with plans to boost 24-26 psi.
Old Jan 12, 2002 | 04:19 AM
Big James's Avatar
New User
Default Re: only use NGK plugs. (boosted3g)
I should have taken a pitcure of what my Denso Iridiums looked like after just a couple of months. The electrodes were completely rounded off. They looked like hell, and performed worse. I learned my lesson. Thankfully it only cost me a set of plugs. I stick to NGK now.
Old Jan 12, 2002 | 05:32 AM
b18bturbo's Avatar
i use this specail race plug from NGK its number 11 plug 6 steps colder
650hp with no prob r5671a is the part number its a race plug you need it 14mm
Old Jan 12, 2002 | 06:19 AM
Arturbo's Avatar
Better than steak
25 Year Member
I hate changing those things out after every run..
Old Jan 12, 2002 | 09:21 AM
VTC_CiViC's Avatar
BCPR7E-11's here.. work great except I have a little trouble starting more often now and the occasion stumble while driving at low rpms. From what I gather it's simply a cold plug issue, but for 10psi, works wonders
tegon-gsr
Jun 4, 2004 11:44 AM
sting94112
Apr 18, 2004 04:26 AM
DSeriesBeeKilla
Jul 8, 2003 03:19 PM
crxb18c5
Aug 5, 2002 07:53 AM
