nitrous engine wear & tear
Old Jan 9, 2002 | 07:56 PM
Cow's Avatar
Cow
Default nitrous engine wear & tear
A friend and I were having a debate and I was hoping someone here could settle it. He claims that using a nitrous kit will not increase engine wear (this based off of some advertising literature I believe.. ). However, I've read countless posts on H-T that state the opposite.. that nitrous will quickly wear down piston rings, seals, etc. Can someone clarify this for me? Thanks..
Oh BTW I already did a search
Old Jan 9, 2002 | 08:05 PM
D-SPEED's Avatar
Default Re: nitrous engine wear & tear (Cow)
obviously if you have more power you are going to stress the internals more...nuff said
Old Jan 9, 2002 | 08:10 PM
01geeser's Avatar
New User
ur pretty much right....rings, valve seals, blah, blah, blah
[Modified by 01geeser, 5:10 AM 1/10/2002]
Old Jan 9, 2002 | 08:26 PM
Cow's Avatar
Cow
Default Re: nitrous engine wear & tear (01geeser)
Ok well let me follow this up then. Would nitrous be more or less strenuous on the engine than a turbo/supercharger?
Old Jan 9, 2002 | 09:27 PM
laughinxxx's Avatar
New User
No. They only real problem with the reliablity of nitrous is the increased number of idiots who get their hands on it as opposed to turbos or SCs.
Old Jan 10, 2002 | 03:50 AM
Mista Bone's Avatar
D Tranny Guru
Nitrous tends to be brutal. It spikes the torque curve at low rpms.
Can you say 200 lb/ft at 3500 rpm???
This is just a SOHC motor also!
Also remember this FACT......
unless using a controller ($250) NOS flows at the same rate, not dependate on RPM's.
You get most power boost at lower rpms.
Also usually get faster times using a lower shift point when spraying.
Old Jan 11, 2002 | 01:55 AM
Big James's Avatar
New User
Default Re: nitrous engine wear & tear (Mista Bone)
Looks familiar! I got 202TQ on my SOHC non VTEC Accord motor when I still had it.
integ_lude
Mar 25, 2008 06:26 AM
The7thG
Honda Civic (2001 - 2005)
Feb 4, 2007 08:05 PM
Defcon2030
Nov 24, 2005 07:43 PM
Chief Brody
Jul 16, 2003 07:20 PM
95hybridcivic
May 5, 2002 08:36 PM
