Boost gauge help
Old May 24, 2002 | 05:40 PM
trunks1001's Avatar
Default Boost gauge help
Does anyone know where in a '00 civic si do i put the vacuum line through the firewall ? What i mean is what opening can i use to feed the vac line through from the inside of the car to the engine bay so i can connect my boost gauge?
Old May 24, 2002 | 05:43 PM
yellow blur's Avatar
Default Re: Boost gauge help (trunks1001)
There should be a grommet on the firewall that you can just pull out. Black plastic grommet to feed your vac line through, mech boost gauge i assume.
Old May 24, 2002 | 05:45 PM
trunks1001's Avatar
Default Re: Boost gauge help (yellow blur)
there was one next to the clutch a black grommet but when i put the line through it didn't go anywhere it just got stuck
Old May 24, 2002 | 05:48 PM
Get a flaslight down in there and see if you can see light coming through. If not keep looking, my integ had one just chilling on the firewall and I used that. Good luck.
Ed
Old May 24, 2002 | 06:05 PM
trunks1001's Avatar
thanks for the reply, which black grommet are you talking about????? I'm still not able to find it. Anyone else know????
Old May 24, 2002 | 10:13 PM
inspyral's Avatar
In my 6g, there's a black grommet with a cluster of wires right next to the clutch cylinder on the firewall. I use it for all my wire/vac pass-throughs
Old May 24, 2002 | 10:29 PM
Ri5e's Avatar
Default Re: Boost gauge help (inspyral)
Or you can drill a small hole right on top of the Big black grommet on the drivers side.
GiNuWiNe
Nov 20, 2005 04:06 PM
blackccoupe
May 18, 2004 07:26 PM
homesauce
Mar 28, 2004 01:33 AM
Pengo
Jul 23, 2002 09:35 AM
falcongsr
Jul 3, 2001 03:14 PM
