What suspension set-up to get?
Old May 24, 2002 | 04:42 AM
1337 Si's Avatar
Default What suspension set-up to get?
I am lost as to what set-up I should get. I was thinking about skunk2's and Koni's, but I really haven't ever heard anythign good about Skunk2's. What do you guys all have? Advice? Let me know!!!
Old May 24, 2002 | 11:11 AM
1337 Si's Avatar
Default Re: What suspension set-up to get? (Boosted Ego)
Anyone?
Old May 24, 2002 | 11:13 AM
jinxproof99's Avatar
New User
i have skunk2's and koni yellows. works good at the track and rides decent on the street. get the tein's if you want all around performance and autox.
Old May 24, 2002 | 11:23 AM
Trigun's Avatar
Default Re: What suspension set-up to get? (jinxproof99)
tiens are cool but i went with zeal b2
Old May 24, 2002 | 11:33 AM
RCSIVTEC's Avatar
get a set of ground control coilovers with ebiach 400 to 600 lbs springs in the front and 1000 lbs springs in the rear with a set of advanced design shocks.
Old May 24, 2002 | 11:35 AM
b18bturbo's Avatar
Default Re: What suspension set-up to get? (RCSIVTEC)
if you gonna go all out check out penkse or the moton setups...
if you gonna go simple design a good set of coilovers should do the trick.
Zeal,Tein,Jic,SRR,Sustec, are all awesome units.
[Modified by b18bturbo, 2:35 PM 5/24/2002]
Old May 24, 2002 | 11:41 AM
RCSIVTEC's Avatar
Default Re: What suspension set-up to get? (b18bturbo)
for my setup i was thinking about penskes because a friend of my has them on talon but i also like the advance design shocks
Old May 24, 2002 | 02:20 PM
1337 Si's Avatar
Well, that is another thing, I want to be able to utilize USDM LCA's on my Civic. I know that with the Teins you need JDM LCA's. Are the Progress coils any good?
Old May 24, 2002 | 02:22 PM
954DR's Avatar
New User
You'll be good to go with a set of GC & Konis.
Old May 24, 2002 | 02:35 PM
Trigun's Avatar
don't you mean ITR LCA's?
Old May 24, 2002 | 09:44 PM
inspyral's Avatar
Default Re: What suspension set-up to get? (Trigun)
To my knowledge, 6g USDM and JDM LCA's are exactly the same. The JDM CTR upper control arms are nifty solid pieces though, unlike the stamped crap that we get.
Oh, and you can't use ITR LCA's on 6g Civics.
[Modified by inspyral, 1:13 AM 5/25/2002]
Old May 24, 2002 | 09:50 PM
bretx0r's Avatar
Default Re: What suspension set-up to get? (inspyral)
my koni ground control setup is AWESOME i can go REALLY low if i so choose, and the handling is smooth as silk even with the stock ground control spring rates ( not at the lowest setting tho )
[Modified by bretx0r, 6:50 AM 5/25/2002]
[Modified by bretx0r, 6:51 AM 5/25/2002]
Old May 24, 2002 | 11:54 PM
saso
Guest
Posts: n/a
I use skunk2 w/koni yellow on my street car must admit they a bit rough for the street.
Old May 25, 2002 | 02:19 AM
SIK IN DA HED's Avatar
New User
Default Re: What suspension set-up to get? (saso)
i recommend kyb agxs and weapon*R dual spring coilovers or skunk2
Old May 25, 2002 | 03:59 AM
1337 Si's Avatar
Default Re: What suspension set-up to get? (dlplayboy)
So I take it that you guys would reccomend Ground Controls over the Skunk2's anyday correct? If so, can I get different stiffness springs witht he kit or will I have to get them afterwards?
Old May 25, 2002 | 08:01 AM
SiRkid's Avatar
H&R sports with KONI yellows! best aftermarket set up for the money IMO!!!!!!
handles really really well!!! and rides nicely(if you turn down the konis a little )
jonnybadboi9
Suspension & Brakes
Sep 8, 2008 08:31 PM
JTN416
Jul 25, 2008 09:57 AM
bibong
20
Dec 3, 2006 09:35 PM
alacard
Suspension & Brakes
29
Sep 13, 2005 03:30 PM
buck02
Oct 10, 2004 12:28 PM
