Did you have to replace bearings when you replaced your rods/pistons?
Did you have to replace the rod and crank bearings when you replaced your rods/pistons? Or did you keep the stock ones?
I'm about to replace my rods/pistons and my mechanic told me that I need new bearings (he didn't look at the engine yet).
Also, does it make any difference if I BLEW my engine (probaly a killed piston)? Would I need new bearings in that case?
Thanks!!
Thanks!!
Re: Did you have to replace bearings when you replaced your rods/pistons? (Sh4rky)
u defineately need rod bearings... the sizes wont be the same and while ur in there u might as well change the mains as well... no point in skimping out and not changing them... it might come back and haunt u in the future
Re: Did you have to replace bearings when you replaced your rods/pistons? (SLPR)
Is it because I blew the engine, or do you need them anytime you put in new pistons/rods?
New User
Why would you skimp on the bearings if you are paying for the pistons and rods? just get new bearings also.
Randy
Re: Did you have to replace bearings when you replaced your rods/pistons? (RGAZ)
I wanted to skimp because it's like another $100 - $150 bucks which I will have to borrow...
Will my mechanic know which clearances of he bearings to get? The engine has to be apart by then, right? Or, is that something I can buy myself knowing which rods I'm getting?
Your mechanice will more then likely plastigauge the existing bearings and find out which size bearings he will need.
Re: Did you have to replace bearings when you replaced your rods/pistons? (nema741)
$100?
Jeez!
Each bearing half is only like $1.75/each! Multiply that by eight, and you have $14 in Honda OEM bearings! And it's not like there's that much additional labor since it's all gonna be apart anyway...
Sigh... shady mechanics...
Jeez!
Re: Did you have to replace bearings when you replaced your rods/pistons? (PyroVTEC)
wow, where do you get factory honda main and rod bearing for 1.75 per? I need to get some of those!!!
New User
i don't know about that.... bearings for my H are about $8 each from majestic (as cheap as it gets for OEM parts)
$100?
Jeez!
Jeez!
Re: Did you have to replace bearings when you replaced your rods/pistons? (schwett)
Get new bearings. If you don't have the money then don't start in the project in the first place.
Ah yes, I forgot to mention, those aforementioned prices are for the D-series motors and not for the B-series or the H-series. I recall the Honda guy giving me a bearing for the H22 motor for like $8/ea, so yeah, those could be the going rate for the twin-cam motors.
fromsupra-to-civic
09-15-2008 05:58 AM
