2 step with Turbo...
Old May 22, 2002 | 08:07 PM
CM-R's Avatar
Default 2 step with Turbo...
When i use my 2 step i love that loud as hell popping it does when i'm ready to launch...Is that bad to do that all the time or is it ok to do it sometimes??....Should i just give it half throttle and run the 2 step or should i just floor it and run the step??
Old May 22, 2002 | 09:49 PM
echo999's Avatar
New User
Default Re: 2 step with Turbo... (CM-R)
what is 2 step?
Old May 22, 2002 | 10:00 PM
b18tdelsol's Avatar
Default Re: 2 step with Turbo... (echo999)
2 step? like.. two rev limiters or something?
Old May 22, 2002 | 10:24 PM
paulzy's Avatar
Default Re: 2 step with Turbo... (b18tdelsol)
haven't tried it with a turbo car, but when I had it in my ybrid I was at WOT
Old May 22, 2002 | 10:25 PM
intekragsr's Avatar
has the rev limiter to launch and rev limiter so you dont over rev. correct me if im wrong
Old May 22, 2002 | 10:45 PM
bigTom's Avatar
Default Re: 2 step with Turbo... (intekragsr)
to my knowledge its ok to do but it will shorten the life span of the turbo... basically try not to do it at every light is what im saying
Old May 23, 2002 | 12:03 AM
DLB1994's Avatar
Default Re: 2 step with Turbo... (ek9t)
ohh god i love my 2 step i can set it at 3000rpms and hold to the gas to the floor and leave at full boost
i got mine hooked up to my clutch
Old May 23, 2002 | 10:50 PM
CM-R's Avatar
Default Re: 2 step with Turbo... (DLB1994)
Ok i'll try not to do it that much anymore only if i need to use it....i love that popping sound though....my two step is activated by a push button mounted on my stick shift.....
Old May 23, 2002 | 10:54 PM
VaporTrail's Avatar
New User
correct. Two stepping sends EGT's through the roof.
Old May 25, 2002 | 02:59 AM
GoldenONE's Avatar
when do you push the button?
Old May 25, 2002 | 04:05 AM
1337 Si's Avatar
Default Re: 2 step with Turbo... (Z00MxYZ)
Get a clutch activation switch because it would be very difficult to hold a switch while gettign ready to launch.
Old May 25, 2002 | 10:51 AM
CM-R's Avatar
Default Re: 2 step with Turbo... (Boosted Ego)
Actually its pretty easy with the button right under my thumb...i just hold it when i'm lined up then when i get a good launch off i just let go...
Old May 25, 2002 | 11:02 AM
jinxproof99's Avatar
New User
some people don't have to hold a switch with their fingers to use a 2step.........
Old May 25, 2002 | 11:18 AM
93LSivic's Avatar
Default Re: 2 step with Turbo... (jinxproof99)
Ahh, the joys of hondata.....
slotec
Sep 26, 2005 08:46 AM
91integraLSVTEC
May 31, 2005 06:48 AM
johnSiR
Sep 7, 2002 10:51 AM
CovertFI
Aug 7, 2002 07:54 AM
-Gambit-
10
Dec 16, 2001 01:03 PM
