Please help me understand my track times.. thanks
Ok i ran last night on the 8th mile my setup is. b16a2 in a 2000 coupe, full interior, eagle rods, wiseco 8to1 pistons, tial wastegate and drag3 turbokit running at 4psi untill my hondata gets here, and BFG (older ones) drag radials. I ran a 9.26@81mph. now heres the thing i dont get my friend ran his hatch its a 93 hatch striped, b16a (stock), tialwg, drag3 at 9psi, M/t Slicks and a dualstage rev for the launch. and his time was a 8.2@81 mph. im pritty sure its my hole shot as my tires spin out till the middle of 2ed gear. I tried droping the pressure and it helped a bit, but no mater who i launch the second boost builds i spin, then when i shift into 2ed my tach does not really drop from 8grand, the car just catches up. then 3ed im ok. Any ideas??? i can afford slicks right now but its looking like my only hope. sure once i get the hondata i plan to have it tuned for 12-15psi **** with injectors and 8to1 compression i should be ok right pluss the help of the 2 stage launch and full throttle shift. But still its no good if i cant get traction oh and i dont have any wheel hop aat all so thats kinda good. thanks for all the help!
Re: Please help me understand my track times.. thanks (94hondahybrid)
work on your launch, and hhow come your running such low boost? just being safe or what?
Rob
Rob
Re: Please help me understand my track times.. thanks (rjardy)
On the track my car really does not use the bottom end, I mean sure i notice a little in daily driving but at the track my turbo spools prity fast as i launck at 5000-6000 prm (seems to work the best). Then the car never drops below 6000rpm so im good to go. The thing about the boost is that i blew my motor with 7psi when the old deltagate over boosted to 20+ and the motor poped. so Im just kinda scared to run it higher than 4psi untill i get my hondata. i did get the tial so i hope that takes care of the spiking. for fuel right now i have a bbk intake and the drag inline pump. what psi could i run with it still being safe...remember its 8to1 compression. also i did try 7psi at the track last night once but then i got a worse time, 9.7@79mph as i span all first and second. well thanks for the help this is really good. keep it coming!
