missing link and still getting check engine???
Old May 22, 2002 | 10:07 PM
integraracer94's Avatar
Default missing link and still getting check engine???
I have a missing link installed with my drag gen III kit, but when I hit boost I still get a check engine? Has anyone else had this problem? When I turn the car off the light is gone and will only come one at boost.
Is there anyway that I could have it upside down? I have the side that has the o-ring and the groove facing up and the Map sensor on top of that, any ideas?
Old May 22, 2002 | 10:14 PM
yellow blur's Avatar
Default Re: missing link and still getting check engine??? (integraracer94)
Heh, at least your missing link works. I think I bought a lemon. I'm running the stock map sensor without the link, and when I hit boost, all is well. I've had it on for 4 days now and everytime I boost, no cel or anything. There really is only one way to install the link, groove side up with an oring there, not sure where the other oring they provide you with goes where.. but im assuming it goes to replace the one on your throttle body? Let me know what happens.
Ed
Old May 22, 2002 | 10:17 PM
Default Re: missing link and still getting check engine??? (yellow blur)
I didn't use the other o-ring I just used the stock one and used the other one they gave me on top. I didnt see any difference between the stock and the one they gave me but maybe I will swap them out
Old May 22, 2002 | 10:27 PM
sushibug's Avatar
double check its not upside down..
Old May 23, 2002 | 02:01 AM
Flamenco-T's Avatar
Default Re: missing link and still getting check engine??? (sushibug)
yeah, double check make sure it's not upside down, just look at the groove on one side and make sure they mate up with the MAP sensor
also, check for the ring not aligned when you install it, it sounded like the missing link doesn;t bleed boost like it needs to..
Old May 23, 2002 | 02:24 AM
Arturbo's Avatar
Better than steak
25 Year Member
You are getting a CEL, but make sure its a map sensor code.
art
Old May 23, 2002 | 03:38 PM
checked the code today and it is definetly a map sensor and ideas? I took it off and it is on the right way and the o-rings are fine.
Old May 23, 2002 | 03:53 PM
TURBOED-TEG's Avatar
Did you hit boost before installing the missing link...you might have blown the sensor, they are cheap from a junk yard...buy another one and try that.
Old May 23, 2002 | 04:19 PM
Default Re: missing link and still getting check engine??? (TURBOED-TEG)
never boosted before the missing link. Went in and pulled the fuse and reset the codes and still gives me the CEL. I will try that.
NJ VTECpowered
Jan 17, 2007 10:06 PM
ROCAFELLA2049
Jun 29, 2006 09:24 PM
spark plugs.
May 11, 2004 09:06 AM
Cyber ITR
Nov 2, 2001 09:55 AM
Turbohatch
Jul 2, 2001 10:35 PM
