What's missing from this turbo setup?
Old May 25, 2002 | 02:17 PM
M.A.R.C.'s Avatar
Default What's missing from this turbo setup?
OK. This is my plan for a basic turbo setup on my car. I'm buying it piece by piece. It's basic as I said, 6psi, on a d16y8, small turbo (maybe go 16g later). I know a lot of people will say bigger turbo or hondata... yes that will come... in time.
>Mitsubishi TD05H-14B Turbocharger
>Pann Auto Turbo Manifold (or maybe sfp)
>TEC Wastegate Canister with 6psi Spring
>Starion/Conquest I/C (or if i can find a cheap drag i/c)
>Custom I/C piping
>HKS SSQV Blow Off Valve
Fuel System:
>DSM 450cc Injectors
>RC Injector wire clips
>255lph Walbro Intank Fuel Pump
>Apex'i V-AFC
Electronics & Gauges, etc:
>NGK BCPR7ES-11 Spark Plugs
>Greddy Turbo Timer (got it already)
>Autometer Sport-Comp A/F Ratio Gauge (got it already)
>Autometer Sport-Comp Boost Gauge
>Autometer Dual Gauge Pod
Miscellaneous:
Oil-line Kit
Gaskets, etc.
Old May 25, 2002 | 04:41 PM
FUP23's Avatar
New User
Default Re: What's missing from this turbo setup? (CivicRyda2k)
Fuel> Vortec 12:1 ?
Everything else seems there
Old May 25, 2002 | 05:47 PM
Soled Out's Avatar
Default Re: What's missing from this turbo setup? (Devin17)
msd 6 btm
Old May 25, 2002 | 07:13 PM
M.A.R.C.'s Avatar
Fuel> Vortec 12:1 ?
nah you wouldn't wanna run the vortec fmu with such big injectors. would run way too rich. the vafc mod (not the hack) seems sufficient for boost below 10psi.
Old May 25, 2002 | 07:31 PM
rjardy's Avatar
you still need something to raise your fuel pressure under boost, the vafc will not do that, it will just allow you to adjust it in incriments......
i am pretty sure you will need an FMU or something else to deliver fuel (hondata)
any one can clear this up ?
Rob
Old May 25, 2002 | 07:50 PM
M.A.R.C.'s Avatar
Default Re: What's missing from this turbo setup? (rjardy)
Rob
You don't necessarily have to raise fuel PRESSURE for boost, just the actual fuel flow into the cylinders. Remember that by raising fuel pressure you therefore increase the fuel flow. With the 450cc injectors the car wouldn't start or idle because it would be flooded. With the V-AFC you can cut some of the fuel flow so the car can idle since 450cc's are big injectors. if you want you can check out http://www.thedropshop.tv/vafc.htm they have a write up on it.
[Modified by CivicRyda2k, 11:52 PM 5/25/2002]
Old May 25, 2002 | 07:56 PM
rjardy's Avatar
WOW i might be a little silly but I HAD NO IDEA YOU COULD DO THAT! Thats cool though. i think i might look into doing that my self. Thanks allot man.
Rob
Old May 25, 2002 | 08:06 PM
M.A.R.C.'s Avatar
Rob
yah from what i heard it works well. It only works for below 10psi. After 10psi it the check engine light comes on (MAP sensor). VTC Civic used it before he had his hondata put in and it seemed fine. Just need dsm 450cc injectors (or RC 440's whatever it is), the vafc, and a intank fuel pump (the stock pump won't be able to flow that much). Just hook it up normally and put the settings in. Those settings on the site are for a d16 civic i think though.
AznPrideYo
Jan 28, 2004 09:54 AM
.RTErnie
Oct 27, 2003 08:36 PM
M.A.R.C.
Jul 7, 2002 10:09 AM
M.A.R.C.
Jun 25, 2002 07:31 PM
zcivic91
18
Jun 18, 2002 07:07 PM
