retart timing?
Old May 25, 2002 | 07:57 AM
Audi A4's Avatar
Default retart timing?
i ahve a drag kit on a ls motor, should i retart or advance the timing, and how much shold i. running 4 pds thanks alot
Old May 25, 2002 | 08:48 AM
b18b98's Avatar
Default Re: retart timing? (DRAG lll INTEGRA)
retard it 2 degrees.
Old May 25, 2002 | 09:11 AM
Audi A4's Avatar
Default Re: retart timing? (b18b98)
ok igniton timing or cam timing?
Old May 25, 2002 | 09:38 AM
turbopimp's Avatar
Since you're only runing 4 psi of boost, ignition timing can be left stock, assuming you're pumping premium fuel. On a B18b , prob no need to retard timing till around 7-8 psi. Then you'll prob want to retard timing at the distributor about 2 degrees. Of course, this is all assuming you have properly installed the DRAG fuel pump and FMU and have no fuel issues...
spoolingb20
Apr 26, 2006 10:46 AM
wrXtian
Mar 25, 2003 03:55 PM
SSBP DC2
Mar 2, 2003 10:47 PM
Audi A4
May 25, 2002 11:05 AM
echo999
May 19, 2002 02:28 AM
