power source for fuel pump
Old May 23, 2002 | 09:42 AM
ludelvr's Avatar
Default power source for fuel pump
Where is the most readily available power source for the fuel pump? I'm talking about the stock fuel pump. I've seen the instructions on how to wire up the relay, but where do I get the stock pump signal wire from?
Old May 23, 2002 | 09:44 AM
rtype11's Avatar
Default Re: power source for fuel pump (ludelvr)
youre confusing me, is "ignition" your answer? dont you have wiring in the car? use it.
Old May 23, 2002 | 09:46 AM
dustin's Avatar
Default Re: power source for fuel pump (rtype11)
use the main relay ?
Old May 24, 2002 | 01:34 AM
inspyral's Avatar
Default Re: power source for fuel pump (94hondahybrid)
You can get stock pump signal from the stock relay, or just tap it directly from the stock pump like I did. It's a yellow wire with a green stripe.
Old May 24, 2002 | 12:44 PM
ludelvr's Avatar
Default Re: power source for fuel pump (inspyral)
Hey inspyral, where is the stock relay located? And would it be a yellow wire with a green stripe for all hondas? Also, when u tapped it directly from the stock pump, did u just run a wire all the way to the engine bay? Thanks man.
Old May 24, 2002 | 09:35 PM
inspyral's Avatar
The stock relay is under the dash, I think. I didn't feel like looking for it, so I just ran the wire back to the stock pump, since I knew where that was.
Old May 26, 2002 | 12:38 PM
ludelvr's Avatar
So what exactly is the advantage of hooking up the power source to the fuel pump as opposed to any other switched power source like the ignition for example?
Old May 26, 2002 | 12:50 PM
inspyral's Avatar
You want the inline pump to turn on/off with your stock pump. You don't want it constantly on when the key is in the ON position.
Old May 27, 2002 | 02:16 PM
ludelvr's Avatar
so does that mean that the stock pump shuts off after the initial start up of the engine or does it only run if the engine is running?
Old May 27, 2002 | 03:56 PM
inspyral's Avatar
Both pumps turn on to prime the fuel system when the key is turned to the ON position, and then turn off. When the engine is started, both pumps are on.
pleej
Apr 8, 2011 11:06 AM
f20cmx5
Feb 10, 2011 10:25 PM
RACEPAK
Feb 10, 2008 10:58 AM
*Boostwerks*
Mar 3, 2005 10:06 PM
platinum00
Feb 4, 2004 01:54 PM
