what cause boost spike??
Old May 22, 2002 | 04:17 PM
KekeK-18's Avatar
Default what cause boost spike??
I have a tial wastegate with profec b. let say went I set it at 8 psi it will spike to 10-11 and the it will settle at 8psi. if I set it at 14, it will also spike up 2-3 psi to 16-17 psi and settle back to 14psi. Why is it doing that?
Old May 22, 2002 | 04:22 PM
GruvyTune's Avatar
New User
Default Re: what cause boost spike?? (KekeK-18)
If you have an EBC, you should try lowering the gain. That is a very common cause of boost spike. Manifold--> downpipe design is another. If you have a source of obstruction or a resonance in your pipe you may have spike or boost "creep"
Old May 22, 2002 | 04:24 PM
MackSpeed-616's Avatar
what manifold are you using?
turbotypeR@SPEC's Avatar
25 Year Member
what manifold do you have?if it is drag,it could be because the wastgate is on one runner.i just got my boost creep problems solved with a new manifold that let me feed the wastgate with all four cylinders.
Old May 22, 2002 | 05:10 PM
KekeK-18's Avatar
Default Re: what cause boost spike?? (turbotypeR)
I have the kooks manifold, I don't have this problem before, the boost was nice and steady....just recently. One thing I did is instead of using Ts for the vacuum lines, now every vacuums is plug into the intake manifold individually.
Synapse
May 1, 2007 08:42 AM
turtle-eg
Apr 18, 2005 02:35 PM
1JDMDOMINICAN
Jan 20, 2005 09:32 AM
RedTegLS
Feb 4, 2004 04:22 AM
