Daily Driven Integra, need turbo, import builders or dag?
well...the cost of the import builders setup is more than twice that of the drag. however, if its worth the money, Ill get that istead of the drag kit.
http://importbuilders.com/forced.htm
Import Builders kit : $6000
Drag Gen III: $2500
Drag Gen III: $2500
Import Builders:
IB "Killer" Turbo Kits for Built motors: Stainless Steel Equal Length manifold totally re-welded by us for strength, steel braid lines, custom piping, all flanges, bolts, filter, TD03/4 (big), HKS Wastegate, HKS blow off valve, HKS Turbo Timer, Greddy Profec B boost controller, Greddy Profec Remote control Button for Steering wheel, Boost gauge, Oil pressure Gauge, Morosso Oil pan, Gauge pod, Earls fittings, 2.75 inch down pipe, flex pipe, 3" Carsound cat, HKS Intercooler, Inline Fuel pump, RC 440 or RC 550 injectors $6000 shipped. (we believe this to be the best kit you can buy with money, as as the graph shows above, it is proven)
New User
Re: Daily Driven Integra, need turbo, import builders or dag? (integra-modder)
$6000 for that kit?
i can build you a custom kit way cheaper than that...
the only thing you need to upgrade with the DRAG kit is the oil return lines... sell the fmu... buy some 440cc injectors and a Hondata stage 2b... a greddy profecB... a few guages here and there... and you probably still have $1500 left to spend on other things, as compared to that import builders turbo kit. you get a tight *** kit with a standalone unit for $1500 less than the IB kit. thats more than enough to convince you to NOT get the IB kit.
if you went with a custom kit... it would probably be around the same price range as the DRAG kit.
Re: Daily Driven Integra, need turbo, import builders or dag? (dlplayboy)
You can get a custom kit for about $1500 if you use a stock intercooler; BOV; and, if you want to, turbo from a stock turbo car and fab your own IC piping. Add Hondata for about $1500 tuned and you're set.
Re: Daily Driven Integra, need turbo, import builders or dag? (NOCARLOSER)
drag III for $2500? is it for an ls? if so where?
lowest i found was 2900 thats with the 10% off at import parts.
Re: Daily Driven Integra, need turbo, import builders or dag? (badnan)
a few guys have IM'ed me offering me kits for 2500 shipped.
Instant message this guy SPOON_BeIgHtEeNsEe, he should be able to offer you a kit for the same price.
http://mywebpages.comcast.net/integr...temp/turbo.htm
check out that page, its an excel sheet that I made and looked around for the parts for the past few days to match that kit. Maybe I dont know where to get the stuff, but my cost is becoming kinda high (next to 6 grand without shipping)
can anyone suggest cheap places to get stuff and or other things to get?
stay awake 24/7 and monitor the Classifieds.........patience my friend.......groupbuys going on all the time also
Re: Daily Driven Integra, need turbo, import builders or dag? (int3gra)
http://members.rogers.com/syndk8/misc/turbo.htm
updated your list..........some prices that are not quoted might be off a little.
send me PM if u find better prices........i will update it.
go drag, that 6k turbo set-up seems quite pricy. a buddy of mine has a new drag kit for sale, he's asking 2650 plus shipping.
Re: Daily Driven Integra, need turbo, import builders or dag? (GudeH23a)
im getting the drag kit, 2500 shipped brand new.
thanks a lot int3gra, Now I just gatta goto school and then look it over...
what manifold do you suggest? (link?)
what oil lines do you think i should get? (link?)
HKS Blow Off Valve for 180? havent seen one...
also, where do I get the apexi universal filter?
FPH001 - $82 190 ltr/hr pump kit Part Numbers
FPH002 - $92 255 ltr/hr pump kit Part Numbers
FPH003 - $107 255 ltr/hr pump kit High-Pressure Part Numbers
i put screen names besides some of the parts.........apexi filter.......Damon501
fuel lines i have no clue.
Manifold is a hard to say.........i am torn between max rev, SFP, and inlinepro
Walbro 255LPH High Pressure Fuel Pump with Kit (new filter screen-tube rubber etc)
1994-1999 Acura Integra
1992-2000 Honda Civic
Part# GSS 342 Kit #400-846
$105 Delivered
http://www.importpoweronline.com
[Modified by int3gra, 5:12 PM 5/28/2002]
$105 Delivered
thanks again...
do you know if the manifold bolts right up or requires modifications?
also, on ebay, they got a **** load of HKS BOV's, most are used from some other models....
is there a specific name for it?
if u want a HKS BOV........... probably the popular one SSQ = Super Sequential
you migh have to shave the block a little for the max rev.......and i think most of them dont allow for AC
[Modified by int3gra, 12:43 AM 5/29/2002]
well then thats out of the question...which allow me to keep AC and have a centralized wastegate location?
ou say the HKS should be no more than 180 on ebay? (new or used, from what car?)
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1831572297 is this one I can use?
you can use that one.....any will work........u just have to weld it onto the piping.
HKS should be around $180 - 200
you can also get it for $200 from http://www.turboevo.com in the monthly clearance section.
not sure which manifold allows for AC.......i have no AC
[Modified by int3gra, 8:16 AM 5/29/2002]
which one did u get?
wait for turbo groupbuy end of June i believe
who is running it?
oh no that is just for a turbo.......not a kit.
there are many good prices in the BEST BUY section for kits.
if you order a dRAG kit then you shouldn't have bought that BOV. Do a LOT of research before you start buying a bunch of chit. It will save you money in the long run.
[Modified by 2K_TEG, 2:20 PM 5/30/2002]
