Which way is your BOV supposed to be pointed?
Old May 23, 2002 | 04:34 AM
_Shadow_'s Avatar
New User
Default Which way is your BOV supposed to be pointed?
I have my turned around, going the opposite way of air flow. Instead of pointing towards the throttle body, its turned the other way. Does it matter?
The reason I ask is because I saw someone elses turbo, and it was different from mine. How do you have yours???
Old May 23, 2002 | 05:55 AM
X2BOARD's Avatar
Default Re: Which way is your BOV supposed to be pointed? (_Shadow_)
The outlet of mine is pointed in the direction opposing the airflow. There shouldn't be any issues with that.. it's just a pressure relief mechanism.
Old May 23, 2002 | 07:20 AM
Coldsi's Avatar
Default Re: Which way is your BOV supposed to be pointed? (X2BOARD)
I pointed mine towards the front of the car just in case water got in there it could drip out.
Old May 23, 2002 | 09:36 AM
rtype11's Avatar
It must be pointed facing the back of your car, everytime you blow off the pressure will push your car forward like a rocket ship. good for 30hp!!!!! and 1 second off your 1/4 mile times!!!!
Old May 23, 2002 | 09:41 AM
TurboSedan's Avatar
New User
Default Re: Which way is your BOV supposed to be pointed? (rtype11)
I tried it and it works great! Everyone should be doing it!
Old May 23, 2002 | 09:57 AM
GSRwBOOST's Avatar
Default Re: Which way is your BOV supposed to be pointed? (97CivicFerio)
how weak.. you only dropped a second?? I dropped 3..... you must not have it aligned properly with the strut brace...
Old May 23, 2002 | 12:31 PM
CovertFI's Avatar
Default Re: Which way is your BOV supposed to be pointed? (94hondahybrid)
i have been wanting to do that just to see how loud it would be. what would also be sweet, it thoes little noise makers that have a fan in it making a wistling noise. you can also put a balloon on it to make the noise. i will try that one day.
STi-Thrill
Jul 1, 2010 07:55 AM
bwm417
Jul 23, 2007 11:11 AM
mechanicnoob
18
Sep 29, 2006 03:34 AM
igo4bmx
Jun 4, 2003 01:41 PM
Suprdave
Jul 15, 2001 11:59 AM
