Need a time slip eval
Old May 25, 2002 | 10:15 AM
Jared's Avatar
Default Need a time slip eval
I know it should have gone faster because of the trap speed because I've run hondas that went low 14s before and they never went that fast, but the spinning street tires didnt help. anyway:
r/t .639
60' 2.279
330 6.384
1/8 9.532
mph 78.74
1000 12.186
1/4 14.387
mph 104.2
Hopefully I'll have slicks by next week. BTW, thats with minimal haltech tuning and only 6psi. and the shittiest street tires i could possibley have had on.
thanks,
Jared
[Modified by Jared, 10:41 PM 5/25/2002]
Old May 25, 2002 | 02:39 PM
Etylorcen's Avatar
Default Re: Need a time slip eval (Jared)
What kind of kit are you running? You should be able to get your 60ft down.
Old May 25, 2002 | 04:44 PM
PrecisionH23a's Avatar
throw slicks on and you might run high 1.9s on the 60ft and high 13s on the quarter. good luck
Old May 25, 2002 | 04:49 PM
H23ludedude's Avatar
Default Re: Need a time slip eval (GudeH23a)
That trap speed is good for mid-low 13's. I just ran 13.7@102 with a 2.20 60'.
Old May 25, 2002 | 04:54 PM
MrSmith's Avatar
Default Re: Need a time slip eval (H23ludedude)
Looks to me like you were trying hard to feather the throttle and not spin it until the very end of second and you finally punched it in the beginning of third? That 60 is actually pretty good for regular street tires.
Old May 25, 2002 | 06:53 PM
speedworks's Avatar
Default Re: Need a time slip eval (MrSmith)
13.20-13.30 with that trap speed
Old May 25, 2002 | 10:35 PM
Prelude Vtec 23's Avatar
Your 60' time is pretty good on street tires. You definately will hit 13's once you get your slicks. Good luck
Old May 25, 2002 | 11:29 PM
DIRep972's Avatar
Smarter than you
thats a really wierd time, u must have launched good (2.2 is good for shitty street tires) and then started spinning after the 60ft. cause your 60ft and mph do not add up to that ET at all.. I used to run 14.1 @ 102 w/ a 2.4 60ft. got drag raidals, turned up the boost 2 psi and ran 13.3 @ 104 w/ a 2.0.. get some good tires on that car and u will run mid 13's.
Old May 26, 2002 | 12:17 PM
Jared's Avatar
Default Re: Need a time slip eval (DIRep972)
Yeah, I was actually trying to feather it out good, but then when it comes on boost it breaks loose so I'm not sure if feathering out hurt me or helped me.
Old May 27, 2002 | 12:00 AM
The Mick's Avatar
Hmm... that is a weird one...
The 60' time isn't that bad; especially for street tires. I'm thinkin' DIRep972 could be right or maybe you bogged a little early off, (then the power came on and started spinning after the 60' mark?) and that hurt your 1/8 mile time and mph. Looks like you made up lots of ground on the 2nd half of the track. I'm guessin' with that mph, you can pull mid to low 13s on those same tires and 12s on slicks.
Did you make any other runs for comparison?
[Modified by The Mick, 2:49 AM 5/29/2002]
Old May 27, 2002 | 01:47 AM
Dutchie's Avatar
Here's my run in a car similar to yours. Shitty street tires also.
r/t 1.373
60' 2.281
330' 5.879
1/8 8.820
mph 83.59
1000 11.358
1/4 13.512
mph 104.5
You could defenitely hit low 13's with good tires.
Old May 27, 2002 | 06:45 AM
Jared's Avatar
Default Re: Need a time slip eval (Dutchie)
Here is a couple more of my runs from that night for comparison:
r/t .753
60' 2.359
330 6.304
1/8 9.425
mph 78.09
1000 12.085
1/4 14.307
mph 103.7
r/t 1.181
60' 2.483
330 6.468
1/8 9.575
mph 78.98
1000 12.448
1/4 14.448
mph 102.91
thanks,
Jared
Old May 27, 2002 | 09:47 AM
speedworks's Avatar
lets put my bogarts on there and up the boost,
slowsleeper
Oct 20, 2004 02:55 AM
B_1_8_hatch
Nov 9, 2003 07:06 PM
Captn. Save A Hoe
Oct 27, 2003 12:50 AM
ALLMOTOR18
Jul 22, 2003 10:38 PM
gigantor
May 24, 2002 11:54 AM
