Spark plug question
Old May 25, 2002 | 09:25 AM
Prelude Vtec 23's Avatar
Default Spark plug question
I am about to put back together my 96 prelude vtec. I am going turbo now also. My question is can I still use the oem spark plugs. Someone told me I should get some aftermarket plugs instead cuz the oem platinum wont handle the boost, because of the heat. Can you guys tell me what you recommend.
Old May 25, 2002 | 09:44 AM
H23ludedude's Avatar
Default Re: Spark plug question (Prelude Vtec 23)
Try search.
Quite a few people recommend NGK bkr7e-11 plugs. The 7 series are one step colder than stock and are better for a turbo car. Mine are in the mail.
Old May 25, 2002 | 11:00 AM
CM-R's Avatar
Default Re: Spark plug question (H23ludedude)
Used to use the NGK-bkr7e-11 and switch to NGK-bcpr7es-11.......both are good spark plugs to use....
Old May 25, 2002 | 11:16 AM
PyroVTEC's Avatar
New User
Default Re: Spark plug question (CM-R)
What's the diff between these two plugs? I see that they're in the same heat range...
Old May 25, 2002 | 12:09 PM
inspyral's Avatar
Default Re: Spark plug question (PyroVTEC)
I'm running 8's with 8lbs of boost, no complaints.
Old May 25, 2002 | 04:37 PM
turbocoupe's Avatar
Default Re: Spark plug question (inspyral)
Here's my thoughts on this. . . .
Yes you need to run a step colder. Everyone here says to use the NGK BCPR7E-11. This is true for tegs, the stock plug is a 6. Hence you go down to the 7.
Now in my case I have a civic. The stock plugs are ZFR5E (somthing to that effect). People tell me I should use the BCPR7E-11. Well that is TWO steps colder. I figured I should be using the 6's.
For Preludes I don't know the stock plug.
Anybody have any thoughts on this? What is correct? 1 step colder for tegs and 2 steps colder for civics? Are the civic folks using the wrong plugs?
[Modified by turbocoupe, 7:38 PM 5/25/2002]
Old May 25, 2002 | 04:41 PM
PrecisionH23a's Avatar
i run NGK BKR7EVX-11
at auto zone or advanced auto they are stock no 4685 and when you run them gap them to about .032. they are really nice plugs, youll like them
[Modified by GudeH23a, 8:41 PM 5/25/2002]
Old May 25, 2002 | 04:50 PM
Default Re: Spark plug question (GudeH23a)
Preludes run a 6 series plug stock.
Old May 25, 2002 | 07:40 PM
Quaalude's Avatar
zfr7f-11...has the extended electrode....got it from Advance Autoparts for 1.99 each....they also have a website http://www.advanceautoparts.com part # 2975
R.S.AKIMOTO
Apr 18, 2007 09:56 AM
Hazymix
Apr 13, 2007 04:29 PM
nickolas388
Oct 26, 2005 08:01 PM
SpeedMonkeyRacing
Apr 24, 2003 08:55 PM
Prelude Vtec 23
May 25, 2002 07:55 PM
