half throttle, full boost question
Old May 22, 2002 | 06:53 PM
Aeka GSR's Avatar
New User
Default half throttle, full boost question
so if im at half throttle and my turbo is spooling full boost... does the fuel increase accordingly? what is telling it to increase?
Old May 22, 2002 | 07:06 PM
Spankee2K's Avatar
Default Re: half throttle, full boost question (Aeka GSR)
If you are at half throttle you will not be at full boost no matter what rpm you are at. You do not hit full boost until you are at full throttle and your turbo is fully spooled up. The fuel is delivered by the ECU by taking the readings of the throttle percentage and rpm. Also if you have a boost dependent fuel pressure riser that also increases the fuel pressure once your in boost.
[Modified by PressurizedB18C5, 4:09 AM 5/23/2002]
Old May 22, 2002 | 08:05 PM
echo999's Avatar
New User
Default Re: half throttle, full boost question (PressurizedB18C5)
This is exactly why you don't want to tap the vacuum source from the intake manifold for your wastegate.. Your wastegate will not open when you really want
it..
Old May 22, 2002 | 08:06 PM
Aeka GSR's Avatar
New User
I've hit full bost while at half.. well maybe 70% (i dont measure it) but ive hit full boost without full throttle.
Old May 22, 2002 | 08:09 PM
Aeka GSR's Avatar
New User
Default Re: half throttle, full boost question (echo999)
i thought that is where you were supposed to tap the wastegate.. its what the kit instructions said to do along with what i've heard on this site... so where is it supposed to be tapped?
Old May 22, 2002 | 08:45 PM
Aeka GSR's Avatar
New User
anyone?
Old May 22, 2002 | 09:17 PM
Ri5e's Avatar
I tap mine at the intake manifold. U can tap it at the compressor too. But if you tap it at the intake manifold, your wastegate will open slower.
Old May 22, 2002 | 09:21 PM
Aeka GSR's Avatar
New User
Default Re: half throttle, full boost question (BG Boost)
im guessing if i tap it at the compressor ive got to drill??? how and where?
there any howto's on the internet?
Old May 22, 2002 | 09:43 PM
echo999's Avatar
New User
I would say definitely tap the source somewhere between the turbo and BEFORE
the intake manifold/throttlebody.
If your wastegate is set at 7psi, and tapped from the intake manifold.. you can run
into situations where you have 10psi worth of boost pressure behind the throttlebody plate, but less than 7psi in the intake manifold. When you suddenly
decide to go full throttle, that whole 10psi will cause 10psi to instantanteously hit your manifold BEFORE the wastegate has time to pop open and relieve the pressure.
I think the reason that the instructions for installations didn't tell you to do this
is probably the fact that some t3/t4e turbos they get do not have a port in the
compressor.. in this case, it's far easier for them to just say to use the
intake manifold.
Many people on this board will tell you the same thing.. and my boost controller
installation instructions (Blitz SBC-id2) says the same thing.
I would definitely tap it after the intercooler, before the throttlebody for the wastegate source... and same for the boost controller.. BOV definitely from the
intake manifold.
Old May 22, 2002 | 10:49 PM
inspyral's Avatar
My conpressor came with a fitting:
Old May 22, 2002 | 11:16 PM
austrian type-R's Avatar
Default Re: half throttle, full boost question (inspyral)
In 5th gear when I only give 40% throttle I can hit near full boost. I've Apexi ACV-R and boosting 1 - 1.2 Bar
rorik
Jul 30, 2008 07:09 AM
echo999
Oct 1, 2002 07:41 PM
bottlefedb18c1
Apr 1, 2002 07:49 AM
