boost creep?
Old Apr 5, 2003 | 01:44 PM
UberTeg's Avatar
Default boost creep?
I have a t25 runnign open downpipe with the stock boost setting, and the boost just keeps going and going and goin. I reached 16psi on the highway b4 i let off Any ideas? The vacuum line is 5/16" and its 3" long
Old Apr 5, 2003 | 01:48 PM
93LSivic's Avatar
Default Re: boost creep? (UberTeg)
Boost creep on a T25 is nothing to worry about. You could get more power by lifting a leg and busting ***.
Just kidding man. Seems to me like the internal wastegate might be going bad on it, or they tell tale crack is there in the turbine housing connecting the flapper door and the exhaust outlet.
Old Apr 5, 2003 | 01:54 PM
UberTeg's Avatar
Default Re: boost creep? (93LSivic)
wouldnt a crack in the housing anywhere cause more lag and possibly more less boost? stupid pos t25 is burning oil too
Could it also be my cheap pepboys $15 sunpro boost guage? It was reading 8psi all night lasty night
Old Apr 5, 2003 | 02:07 PM
93LSivic's Avatar
No a crack at the flapper wouldnt let the boost stop....so you would get creep. I doubt its your boost gauge, not unless theres a hole in your line going to it.
Also inspect the vac line going to the wastegate.
Old Apr 5, 2003 | 02:20 PM
UberTeg's Avatar
the wastegate vacuum looks good. Its 5/16", is this too small? Also wouldnt a hole in the boost guage's vacuum line leak boost out, causing lower readings?
hx for your help, i'll prolly just buy a 14b and rebuidl it liek i should have done in the first place
Spaceballsthelunchbox
Sep 4, 2010 02:52 PM
ericstambaugh07
Jun 23, 2007 09:04 AM
twenty
Jun 13, 2005 04:07 PM
HybridCoupe
Jun 28, 2002 05:13 PM
