Dowel Pin height?
i have a b16b that has been decked and the head has been machined for straightness.. would i need to shorten the height of the dowel pins in order for the head to seal properly.... since my head is leaking oil form between the head and block...right where the power steering is and from behind the head near the alternator... Thanks
If the head has never been machined before and If you only took off a small amount I personally wouldn't worry about it, what headstuds or headbolts are you using and also what headgasket are you using?
Adi
Adi
i am using aebs head studs, stock gasket, but the head was taken off and then the same gasket was used twice... they did it at aebs before they sent me the motor
