Did you double-nut your ARP studs?
Old Apr 5, 2003 | 03:15 PM
B18EG6's Avatar
Default Did you double-nut your ARP studs?
Well... EVEN tho i didnt torque my headstuds down to spec..... when i removed the head, I was able to turn the studs by hand.
I thought maybe double nutting would help when I put them back in.
Do you guys double nut your headstuds? What torque do you tighten the studs down to when you do?
Old Apr 5, 2003 | 03:16 PM
Tinker219's Avatar
Default Re: Did you double-nut your ARP studs? (B18EG6)
ive heard 10ft-lbs. I dont see why more would be harmful, just dont overdue it. I plan on double-nutting mine when I start my build-up tonight or tomorrow...
Old Apr 5, 2003 | 03:18 PM
B18EG6's Avatar
Default Re: Did you double-nut your ARP studs? (Tinker219)
so far i just double nutted them down to 25 ft lbs.... do you think this is too much?
Old Apr 5, 2003 | 03:20 PM
Tinker219's Avatar
i would think that should be perfect. I will try that myself
Old Apr 5, 2003 | 03:24 PM
B18EG6's Avatar
Also I just took a rough measurement..... with the studs torqued down to 25 ft/lbs, there is roughly 3.5" (+/- about 1/16") from deck to top of threads... is this enough for the nuts to screw on without needing more washers?
If no one can tell me I will go try and measure i bolts somewhere around here...
Old Apr 5, 2003 | 03:50 PM
B18EG6's Avatar
Here is a bump, and a picture I drew on the way out my door...
I gotta go eat with the 'rents. Do these measurements allow enough room for using just the one washer?
in case you couldnt tell, these measurements were done with a ruler capable of only 1/8"
Old Apr 5, 2003 | 03:53 PM
VaporTrail's Avatar
New User
i thread mine in hand tight, and turn 1/3 turn double nutted. Thats it.
Old Apr 5, 2003 | 04:25 PM
InfamousRS's Avatar
Default Re: Did you double-nut your ARP studs? (VaporTrail)
I did about the same thing....worked fine for me...going onl 10,000 miles with no problems...
Old Apr 5, 2003 | 05:18 PM
B18EG6's Avatar
Default Re: Did you double-nut your ARP studs? (InfamousRS)
okay... you think i should back mine off at all?
Old Apr 5, 2003 | 05:19 PM
inspyral's Avatar
I used the double-nut method, and torqued to about 15-20 ft-lbs, no problems whatsoever.
kornerk12
13
Aug 7, 2009 02:46 PM
nitroice40
Apr 20, 2008 06:39 AM
fastludeh22
Apr 10, 2004 10:25 AM
yellowturbo
Mar 11, 2004 10:14 AM
jdm_gsr
Dec 9, 2003 05:18 AM
