Engine Spooge?
Old Apr 4, 2003 | 03:33 PM
ion_four's Avatar
Default Engine Spooge?
I've had a catch can half-assedly hooked up for a few hundred miles, meaning it was hooked up to the valve cover and PCV but not to the intake pipe on the turbo because I was too busy/lazy to tap it...
After those few hundred miles it had about 2-4 oz. of watery/puke looking stuff in it, like indonesian peanut sauce (if anyone knows that) and smelled like gas. My question is WTF?
There is NO coolant in my oil, nor oil in my coolant, so is this just a mixture of the vapors from the engine and condensation from the open port to the atmosphere? Anyone have any pics of their engine spunk?
Old Apr 4, 2003 | 04:40 PM
B18EG6's Avatar
Default Re: Engine Spooge? (ion_four)
the only splooge my engine showed me was this
Old Apr 4, 2003 | 04:44 PM
lazerus's Avatar
Default Re: Engine Spooge? (B18EG6)
just an indication that it likes boost.... THAT MUCH
Old Apr 5, 2003 | 01:49 AM
ion_four's Avatar
seriously man, that looks sketchy dripping out of a hole what the hell is that crap, anyway?
Old Apr 5, 2003 | 02:38 AM
MiraiZ's Avatar
looks like burnt coolant
Old Apr 5, 2003 | 03:17 AM
speedworks's Avatar
Default Re: Engine Spooge? (MiraiZ)
i believe its flubber. take some and throw it on the ground and see if it bounces.
Old Apr 5, 2003 | 05:59 AM
94TealGSR's Avatar
Default Re: Engine Spooge? (speedworks)
hahaha!!
Old Apr 5, 2003 | 06:28 AM
Mr. Softee's Avatar
Default Re: Engine Spooge? (94TealGSR)
ive seen that **** in the bottom of my oil pan before. i too, believe it is flubber.
Old Apr 5, 2003 | 10:25 AM
intekragsr's Avatar
Default Re: Engine Spooge? (94goldjungsr)
Actually that is coolant mixed with oil. Go to your garage and mix a little coolant and oil in a waterbottle, shake it really hard and you will get the same stuff, except when its heated it turns gooeyier.
I dont think its a good sign. When mine did that, I had a slightly blown headgasket.
[Modified by intekragsr, 7:27 PM 4/5/2003]
Old Apr 5, 2003 | 10:51 AM
MikeMAN's Avatar
i vote for new headgasket...
mike
Old Apr 5, 2003 | 10:54 AM
Armed Ferret's Avatar
Default Re: Engine Spooge? (intekragsr)
just curious, but how does one obtain a "slightly" blown headgasket?
Old Apr 5, 2003 | 10:59 AM
intekragsr's Avatar
Default Re: Engine Spooge? (SlowRedTeg)
Well......I was over heating slighty at idle, and I was slightly losing oil/coolant, and when I inspected it, it was slightly cracked. So instead of slightly blown, I guess it was slighty cracked
Old Apr 5, 2003 | 11:00 AM
MikeMAN's Avatar
its like honda's ECU's and their fuzzy logic nature. The extra conditions of boolean, almost true, almost false
mike
Old Apr 5, 2003 | 12:55 PM
ion_four's Avatar
Default Re: Engine Spooge? (MikeMAN)
mike
are you talking about my description or his pic? My "spooge" doesn't have a greenish tint to it, it's really about the color of peanut butter...I'm not having any driveability issues and no smoke from the exhaust or fluids where they shouldn't be, so if my gasket was blown, would it hurt to put off changing it for a couple thousand miles or so? I'll be out of school in May and I was planning on rebuilding anyway...
Old Apr 5, 2003 | 01:13 PM
MachAF's Avatar
Collant and oil won't mix. I have a milk jug half oil and half coolant, coolant is all at the top. And doesn't look like that when shaken either.
Old Apr 5, 2003 | 01:21 PM
MikeMAN's Avatar
Default Re: Engine Spooge? (MachAF)
i don't think u can shake it at 8000rpm+
mike
Old Apr 5, 2003 | 01:50 PM
B18EG6's Avatar
My picture is from when I used pure coolant in my motor for like a year. I was told those chunks and goo is the silica precipitating out of the coolant due to lack of distilled water... it was kinda sandy
Old Apr 5, 2003 | 03:11 PM
MachAF's Avatar
interesting.
Old Apr 6, 2003 | 06:44 AM
johnisenglish's Avatar
My friend ran his '87 Blazer with a dead head gasket for 3 weeks or so a while back. Needless to say, that engine died. ALL the coolant and oil had turned into that "spooge" stuff... nasty...
At least doing the swap was fun
integra_101
Mar 16, 2010 09:39 AM
adeline
Jul 22, 2005 02:20 PM
Tad
Feb 6, 2005 04:15 PM
return_2020
12
Dec 30, 2004 01:13 PM
Sinner
Jun 16, 2003 10:09 PM
