need help with turb setup
Old Apr 6, 2003 | 01:52 PM
JimmyT89's Avatar
Default need help with turb setup
When I accelerate, the pressure releases around 4k. When i shift gears it does the same thing and eventually in 5th, my rpms won't exceed past 3 1/2k. I have a97 accord with a 96 h23 in it. I was told that that cause of that could be because of the ecu. the obd-2 ecu "learns" and redoes the a/f ratio to try to get zero boost. Am i correct? Any suggesstions or ideas? Also, after the swap my car would vaccum at 10 at idle N/A and that i cant figure out what the problem is. It also stalls to when the rpms drop. PLEASE HELP....
Old Apr 6, 2003 | 08:34 PM
JimmyT89's Avatar
Default Re: need help with turb setup (JimmyT89)
someone has to have some sort of answers to this
Old Apr 6, 2003 | 08:44 PM
Adi Radoncic's Avatar
On Fire!
Do a Compression test, Check your timing, Check your ignition timing, check your vacum lines, check your plugs..
Than get back to us and report...
Adi
Old Apr 7, 2003 | 12:28 AM
TeStUdO's Avatar
Default Re: need help with turb setup (newgsr)
post it in the tech forum also
314househead
Apr 20, 2011 11:15 PM
SPLIT2NDEJ8
Mar 1, 2010 01:37 AM
atownturbo
May 20, 2009 07:08 PM
leoaa777
Aug 10, 2008 05:10 PM
regime
Jun 6, 2004 04:30 PM
