wastegate setup????
Old Apr 6, 2003 | 03:01 PM
1tyme's Avatar
Default wastegate setup????
which vacuum hoses go where? i have a delta wastegate and i have one hose running from the side of the wastegate to same vacuum source as my boost gause and fmu. seems to run fine but wastegate makes a funny clanging metal sound. all my frens have theirs running from the side of the wastegate to the nipple on the side of the snail. i tried this but i end up boosting 10lbs at like 4000rpm, which is way too much for me. do i have mines hooked up wrong or do i need a boost contorller or sumtin. could someone give me a break down of were the vacuum hoses are supposed to go and what is the vacuum source on the top of the wastegate for.
Old Apr 6, 2003 | 03:28 PM
TeStUdO's Avatar
Default Re: wastegate setup???? (1tyme)
what is the wastegate spring set at?
Old Apr 6, 2003 | 03:46 PM
1tyme's Avatar
Default Re: wastegate setup???? (00si5)
i'm not sure what the wastegate spring is set at i think 6-8lbs cause thats what the guys i bought the kit from was boosting on his car. does anything go to the nipple on the snail? how is eveyone elses wastegate hooked up? anybody
Old Apr 6, 2003 | 04:49 PM
TeStUdO's Avatar
i set my vacuum up on the compressor nipple too, it might be your spring or it might be the notorious boost creep w/ that sorry *** wastegate. buy a tial
Old Apr 6, 2003 | 05:12 PM
intekragsr's Avatar
the side port should be a vacume after the throttle body. The top port is for and EBC or MBC.
Old Apr 6, 2003 | 05:29 PM
1tyme's Avatar
Default Re: wastegate setup???? (intekragsr)
so if i get a mbc and run it off the top port would that go to the nipple on the snail? and would i still have to run the side port to the intake mani?
Old Apr 6, 2003 | 05:30 PM
intekragsr's Avatar
correct
btw, i am lookin to moving to hawaii =D
[Modified by intekragsr, 2:31 AM 4/7/2003]
Old Apr 6, 2003 | 05:44 PM
integra_gsr98's Avatar
Cap the vacuum nipple on the turbo.
Run Vacuum from the back of the intake manifold to a t which provides vacuum for the wastegate and brake booster, as well as whatever else you must hook up (BOV, FPR, etc) and you will be good to go.
Old Apr 6, 2003 | 05:47 PM
intekragsr's Avatar
Default Re: wastegate setup???? (integra_gsr98)
dont tap all the lines to 1 source. use fpr, brake booster, ect ect
flangemastermike
Jun 13, 2007 04:46 AM
highmilehatch
Oct 15, 2003 07:44 AM
ebp 99 si
Jun 15, 2003 07:45 PM
turbo se
Jun 13, 2003 11:33 AM
SolidSpruce
Aug 2, 2002 10:00 PM
