Big hondata problem, help!! thanks
Old Apr 6, 2003 | 07:06 AM
turboex's Avatar
Default Big hondata problem, help!! thanks
OK engine was just rebuilt. When ever the hondata cable is pluged into the ECU the car will not go over 1,000rpm without back firing and missing as if the plug wires were wrong. The setup is a 3b with 450dsm's However when i put a nonhondata chip in the ecu or i just unplug the hondata box then the car is driveable. It just uses twice the fuel due to digger injectors. any ideas? can i send the box back for it to be fixed?
Old Apr 6, 2003 | 07:42 AM
boosted hybrid's Avatar
Default Re: Big hondata problem, help!! thanks (turboex)
Is the light flashing or steady on the blue box when you plug it in?
Old Apr 6, 2003 | 07:01 PM
Spunkster's Avatar
HAs the car been tuned wiht the Hondata, or are you using just a base map, or is it just a blank chip?
Old Apr 6, 2003 | 07:02 PM
turboex's Avatar
Default Re: Big hondata problem, help!! thanks (Spunkster)
its just a base map
Old Apr 6, 2003 | 11:57 PM
Flamenco-T's Avatar
maybe you got the wrong map...check and see if hte light on the box is flashing, or non existent at all
stan
waynebennett77
Dec 31, 2012 09:34 AM
THEUSED
Mar 13, 2006 07:27 PM
ladysman
May 27, 2005 10:03 AM
-iLLuZioN-B18C1
Dec 28, 2004 01:06 PM
Turbo-Honda
May 24, 2004 05:43 PM
