Cooling Question
Old Apr 4, 2003 | 06:41 PM
420aNT's Avatar
Default Cooling Question
Will I have any cooling issues with my fans mounted in this position?
Old Apr 4, 2003 | 06:58 PM
DeepSi's Avatar
Default Re: Cooling Question (18gTeg)
i think it depends on what type of fans they are (pusher/puller) and how you wire them up (polairty for the motor), i believe.
Old Apr 4, 2003 | 06:59 PM
greddyturboGSR's Avatar
I don't think you will have any problems with the fans pushing air through the radiator instead of sucking it through........I don't have any personal experience with this but it almost seems like cooling would be more efficient with the fans that way although im sure in the end pushing/sucking doesn't make a big difference.
Old Apr 4, 2003 | 07:02 PM
420aNT's Avatar
Default Re: Cooling Question (DeepSi)
these fans can be used either or. You just need to switch the polarity and switch the blades around. They are pushing right now.
Old Apr 4, 2003 | 07:23 PM
DeepSi's Avatar
well, if that is the setup then you should be fine. good luck
Old Apr 4, 2003 | 07:25 PM
420aNT's Avatar
thanks for the encouragement!!! This car has cost me a small fortune and it seems to never end
Old Apr 4, 2003 | 07:29 PM
bambooluv's Avatar
you should IM turbodandandee on this board he did the same mod to his fans and converted them with the wiring. Hope that helps-pdang
Old Apr 4, 2003 | 07:30 PM
420aNT's Avatar
Default Re: Cooling Question (bambooluv)
thanks I will do that
Old Apr 4, 2003 | 08:07 PM
420aNT's Avatar
ttt
Old Apr 5, 2003 | 09:46 PM
420aNT's Avatar
bump
Old Apr 5, 2003 | 10:09 PM
.RTErnie's Avatar
what kind of kit do you have? Im particularly interested in the piping. and what kind of manifold are you running? thanks
eric
Old Apr 6, 2003 | 07:41 AM
420aNT's Avatar
Default Re: Cooling Question (RTErnie)
It is a custom kit. I fabbed all the piping it is all mandrel 2.5". The manifold is a Meng design that I braced. The turbo is a Precision SC54, Tial 35mm HP Wastegate, HKS SSQV BOV, Full 3" exhaust from the turbo to my Greddy Power Extreme 2 exhaust with the bottleneck removed. I have 1 extra o2 bung welded in for the wideband when on the dyno. The intercooler is a PWR piece. Intake manifold is JG Edelbrock, Golden Eagle Fuel rail, 780cc injectors, Golden eagle cam seals, Venom Cam Gears and much more.
phoxking
Apr 10, 2011 02:05 PM
jDMJeRk
May 4, 2005 07:43 PM
J2turbo21
Mar 2, 2003 10:23 PM
servion
Apr 1, 2002 10:53 PM
