Questions Running DSM injectors, please help-- did a search!
Alright-- So i've got my DSM injectors, what else do i need. I know i need a resistor box from a CRX, but do i need obd-1 Clips?? My motor is obd-2 so am i gonna have to use those for the clips?? Also, anyone know how to install a v-afc for a non-vtec motor??
Re: Questions Running DSM injectors, please help-- did a search! (integranator)
yes you need the clips, check hondata.com for the wiring diagram. i cant believed you searched and didnt find anything this topic is always on here
obd1 clips from the yard...
dont need a box, just get 10 ohm resistors from radio shack $4 total... u need 4 and wire them through the yellow black wire..
the factory clips will work fine.
if you look at the injector plug while it's facing you, there's the 2 prongs inside. between those 2 prongs on the top of the plug is a rib. take a knife and cut that rib off and the factory clips will plug right in.
Re: Questions Running DSM injectors, please help-- did a search! (Flamenco-T)
Yeah the rib on the DSM injectors. I went to plug mine up yesterday but realized they diden't go on (even though I have OBD1 clips) because of that rib on the injector.
I left it alone, and later found out that its ok to remove this with a utility knife so the injector clips fit.
Other than that it was a smooth install. I used the stock seals and dremeled them out a tad and every thing fit fine, and looks real nice. Cause at least if it don't work, it will look nice.
lol
cheers
lol
cheers
Black R
06-17-2004 01:34 AM
