Millionth HACK problem...wiring diagram ?'s?
Old Apr 6, 2003 | 01:11 PM
Tinker219's Avatar
Default Millionth HACK problem...wiring diagram ?'s?
To make a long story short, tried the SMC on my gfs 93 del sol si(d16z6)...didnt work. Tried Uberchip, Didnt work. The car repeadedly runs rich, to the point where it wont even start, always throws code 43(fuel system), and Im just getting fed up. Injectors tested within .5 ohm of eachother, and so did the injector wires.
I decided to try the VAFC hack, and upon browsing the installation instructions, I find that the SMC diagram and the VAFC diagram conflict.
The SMC says that the MAP wire is the same as one of the VAFC VTEC wires. WTF? HELP ME, IM GOING INSANE...
Old Apr 6, 2003 | 02:09 PM
Tinker219's Avatar
Default Re: Millionth HACK problem...wiring diagram ?'s? (Tinker219)
can anybody help me find wiring diagrams at least so I can narrow that part down???
Old Apr 6, 2003 | 02:14 PM
Poop111444's Avatar
The Apexi website has the instruction manual online, and color codes for assorted honda ECUs. I would go by whatever that says.
@irborne's Avatar
i believe you're not supposed to use the SMC together w/ the VAFC
Old Apr 6, 2003 | 02:16 PM
Tinker219's Avatar
Default Re: Millionth HACK problem...wiring diagram ?'s? (@irborne)
thanx
the SMC MAP is different the the AFC MAP on the wiring diagrams. they should be the same...this is why I need a true diagram for the car, because I dont know which diagram to believe...
Old Apr 6, 2003 | 03:59 PM
Infinity_Racer's Avatar
thanx
believe the one thats on Apex-i's website...
Old Apr 6, 2003 | 04:20 PM
Tinker219's Avatar
Default Re: Millionth HACK problem...wiring diagram ?'s? (Infinity_Racer)
hmm...that could be why the smc didnt work on my gfs car, because the MAP wire was in the wrong spot. i will go try everything exactly to plan...thanx guys
M-EJ1's Avatar
Have you ever had a missing link or check valve setup on the MAP sensor? Check to make sure you put the O-ring back on under the map sensor when you re-installed it. If not, that's probably the source of your problems. Vacuum leak, and the MAP sensor doesn't know what to do.
I had this same problem, car ran super rich, idle surged, it had no power and I kept fouling plugs and fouling my O2 sensor (code 43 usually means fouled O2 sensor). Turns out when I took my check valves off I forgot to put the O-ring back on under there, and I fought with the car for like 2 months trying to figure it out.
Worth a shot.
Old Apr 6, 2003 | 04:22 PM
Tinker219's Avatar
Default Re: Millionth HACK problem...wiring diagram ?'s? (M-EJ1)
i did a search, and found your previous threads before I posted...I will re-check, maybe it was torn or something....
Old Apr 6, 2003 | 05:36 PM
M-EJ1's Avatar
That and make sure your map sensor is good and the little nipple on it is not plugged, and the connection on the throttle body isn't plugged either.
Old Apr 6, 2003 | 05:50 PM
Tinker219's Avatar
k i flipped out and kicked the ******. now I need a new front end.
checked map, GOOD.
rewired afc, NOTHING CHANGED.
turned afc all the way down, -50. nothing changed.
PLUGS STILL SOAKED WITH FUEL(tried cleaning with torch, new plugs too, still nothing)
as far as I know, they are dsm 450s.
i tried 3 chips....JET, Uber(gsr), Uber(d16), neither fires.
I have spark, it wants to fire, but it wont catch. Im seriously pissed off
Old Apr 7, 2003 | 08:04 AM
GraphiteAccord's Avatar
Cody, try going back to stock injectors just for the sake of it. if it fires on stock injectors and stock ecu, then it could possibly be the injectors your using aren't sealing, and just dumping fuel into the motor. Have they been flowed/checked out? maybe try them on a dsm known to run good? Sounds as if everything else is correct....
Old Apr 7, 2003 | 08:14 AM
Tinker219's Avatar
Default Re: Millionth HACK problem...wiring diagram ?'s? (GraphiteAccord)
Im going to put stock injectors back in(out of my brothers 89 civic, so I dont have to undo the resistors) just so I can move del sol so taht I can test-drive my brothers car. If that works, i will try another set of DSMs. this means I will have to go buy ANOTHER 2 sets for my engine becuase I had to use 1 of my 2 to replace HIS bad set. you confused yet? try being me...oh ya, ill be running 8 dsms in my build up, that may help clear some confustion...
Old Apr 7, 2003 | 08:17 AM
It really sounds to me cody that you have a leaky set of injectors. Pump primes, and the injectors don't close all the way afterwards. Also, may want to look at your fuel pressure when you prime, and don't start afterwards, see if the pressure slowly or quickly goes down, if it doesn't hold pressure, then obviously the injectors are leaking.
Old Apr 7, 2003 | 08:31 AM
Smashback's Avatar
Cody, if you are using a chipped ECU with the AFC, did you try cutting the jumper wire on J1 and then messing with the AFC?
Old Apr 7, 2003 | 10:41 AM
Tinker219's Avatar
Default Re: Millionth HACK problem...wiring diagram ?'s? (Hatchblack)
j1 is by the eeprom correct? If so, then there is no wire going into/out of j1. Did JET even chip the friggen ECU?
Old Apr 7, 2003 | 12:09 PM
Tinker219's Avatar
OK, new update. went to crank the car after school just to see what would happen...engine freewheels, just spins. GREAT!
a.) washed rings away to nothing...
b.) timing belt slipped a tooth or two.
c.) My gfs gonna KILL Me when she gets back from SB....
ps...plugs are all tight too btw...
Old Apr 7, 2003 | 05:26 PM
DIRep972's Avatar
Smarter than you
why did the timing belt skip?
Old Apr 7, 2003 | 07:21 PM
Tinker219's Avatar
Default Re: Millionth HACK problem...wiring diagram ?'s? (DIRep)
ok i was just freaking out. I got it started on the stock injectors and verified that the afc hack works. i had it set at -50 for the 450s, and i wasnt getting any gas to the stock injectors. I put it back to 0, and fired right up, perfect idle, everything. Of course I didnt drive the car because of stock injectors, but I have 1 set of DSMs to try. If those dont work, we are back to FMU
looks like Joe(graphiteaccord) was right, the 450s were constantly dumping fuel into the cylinders, obviously not letting any spark light...
where can i get my other 4 sets of DSMs cleaned, rebuilt???
Old Apr 8, 2003 | 07:57 AM
Tinker219's Avatar
my final set of 450s worked! car runs great, no bogging, actually hits 2psi in nuetral she will use the BOV as her horn now because she doesnt have a horn. Still have CEL 43, but the car runs great, so no complaints. Im assuming the 02 sensor is pretty much toast from the constant flow of straight fuel through it...
thanx all for the help...
[Modified by Tinker219, 11:59 AM 4/8/2003]
White98LS
Jul 7, 2011 03:31 PM
kanjia
Jun 10, 2006 01:54 PM
WTR
Jan 2, 2006 09:02 AM
DC2 Mang
Dec 23, 2005 08:11 AM
tyflip2
Dec 3, 2003 05:53 PM
