opinions on a block gaurd please
Old Apr 6, 2003 | 05:50 PM
gsrcivict's Avatar
Default opinions on a block gaurd please
I was thinking about getin a block gaurd and just wanted to get some opinions and fact from the honda-tech specialists. I have a built gsr bottom end with a t3/t4 E turbonetics turbo and hondata s200. Will be running 10-12 psi daily and 15 on race gas at the track. THANX fellas!
_______
Old Apr 6, 2003 | 05:51 PM
VisualAutoMotoring's Avatar
Default Re: opinions on a block gaurd please (gsrcivict)
that's pretty much the setup i'm running right now but on a B16...i used the Nuformz blockguard which seems to be holding up.....i'm also running an InlinePro gasket....JE 9.0:1/Eagle Rods
Old Apr 6, 2003 | 06:16 PM
gsrcivict's Avatar
Default Re: opinions on a block gaurd please (ProjectEF)
how much power you get outta that b16? where did you get the nuforms from?
thanx
Old Apr 6, 2003 | 06:19 PM
havent really dynoed it yet or tuned it.....the previous owner had a similar setup and put 310 whp.....
i bought the blockguard a while ago....
InlinePro i believe has a very good blockguard...
http://www.inlinepro.com
Old Apr 6, 2003 | 06:41 PM
gsrcivict's Avatar
Old Apr 7, 2003 | 03:30 AM
gsrcivict's Avatar
Old Apr 7, 2003 | 03:54 AM
vtecdelly's Avatar
my buddy just put the inlinepro blockgaurd in his type-r had a few fitting issues but seems to work good.. i have a b16 got the inline pro head gasket and block gaurd and manifold ..really like the products... now if my turbo would evercome in...
Old Apr 7, 2003 | 09:51 AM
gsrcivict's Avatar
Default Re: opinions on a block gaurd please (vtecdelly)
anyone have an opinion on which is better between, in-line performance, golden eagle, or a nuformz block gaurd? thanx
Old Apr 7, 2003 | 09:55 AM
genop's Avatar
I think a block guard is an awsome option if you dont have the money for sleeves. The only time you hear horror stories about block guards is when people install them wrong, or like a couple years ago when some of them had cooling problems. Just make sure you dont distort the sleeves when you do the install, and I havent heard anyone talk about cooling problems recently so I dont think you need to worry about that.
BTW where are all of the anti-block guard people? They usually chime in by now
Old Apr 7, 2003 | 10:19 AM
gitwidit's Avatar
I've been running the str block guard for quite some time w/ no probs. What I found out after the fact though is if you are going to bore the bottom have them do it with the blockguard in place, makes sense.
Old Apr 7, 2003 | 10:32 AM
gsrcivict's Avatar
Default Re: opinions on a block gaurd please (GITWIDIT)
what if the blocks already been bored? (20 over I think)
Old Apr 7, 2003 | 10:38 AM
genop's Avatar
The block guard would still fit the same, but the sleeves might distort a little easier since the sleeve is thinner....
Old Apr 7, 2003 | 08:48 PM
gsrcivict's Avatar
Default Re: opinions on a block gaurd please (genop)
Old Apr 7, 2003 | 09:04 PM
BoostedSi's Avatar
Make sure you put the blockguard in before any machine work. I had sleeves distort putting a block guard in after the sleeves were bored to 81.5.
Old Apr 8, 2003 | 07:34 AM
gsrcivict's Avatar
Default Re: opinions on a block gaurd please (BoostedSi)
what do you mean distort? did they fail? So I shouldnt put one in? my block has already been bored to 81.5.
Old Apr 16, 2003 | 07:26 AM
drjondurst's Avatar
how hard is the install?
J1A1H
Sep 30, 2006 03:43 AM
LilCivic04
May 31, 2005 09:12 AM
seen4ever
Mar 1, 2005 12:18 PM
yellowhonda88
Feb 6, 2004 12:33 PM
gsrcivict
Apr 6, 2003 06:40 PM
