How safe?? Turbo R
Old Apr 5, 2003 | 09:12 PM
-=-'s Avatar
Default How safe?? Turbo R
How safe can a B18c5 motor go with a stock motor(pistons/rods)? stock except inline pro headgasket. with Fuel/tuning.
A friend of mine has a t3/t4 turbo, hes only putting down 220hp @ 10psi People said its the inline pro headgasket that is robbing him of power. Is it safe to take off the headgasket and run about 5 psi? possibly more power? They said it made hes compression to low. some guy up here had a 254whp/170lbs tq @ 5psi.. he didnt mention any pistons or rods or anything in hes posts.
220 at the wheels isnt that weak? for 10 psi.. how can he get more power? pistons and rods will be on the motor somewhere in december..
Old Apr 5, 2003 | 09:22 PM
1fstevo's Avatar
New User
Default Re: How safe?? Turbo R (-=-)
Headgasket is not the cause to not have enough power. Probably bad tuning did.
Old Apr 5, 2003 | 09:27 PM
-=-'s Avatar
Default Re: How safe?? Turbo R ([Evo]Hybrid)
The people who tunned it said the head gasket was thick and it robbed him of power.. Anything else other then tuning that might be the problem?
Forgot to mention. when hes crusin around at low rpm the meter is in lean. when hes in boost it goes to rich. is that normal?
[Modified by -=-, 1:28 AM 4/6/2003]
Old Apr 5, 2003 | 09:32 PM
ITR41's Avatar
New User
never go by a AF gauge without a wideband.....get a good EGT gauge it is more accurate. also, the inline pro HG is a safety measure and those cars go very fast on stock internals. I have the inline pro HG too on my ITR. I hope to dyno soon as well....220whp isn't very good for 10spi really, but you have to look at the type of dyno it was....I know of a sentra that put down 220whp on a mustang dyno and 325whp on a dyno jet.
Old Apr 5, 2003 | 09:41 PM
-=-'s Avatar
Default Re: How safe?? Turbo R (ITR41)
Um im not sure what kind of dyno it was, ill ask him when i see him i doubt he'd know because the shop took hes car and did everything when he wasn't around. what is the ideal hp he should be expecting @ 10 psi. it is safe to boost at 10psi?.
By the way whats your set up? dyno #s? track times?
Old Apr 5, 2003 | 09:53 PM
boosted hybrid's Avatar
Here is a stock block itr that I tuned running 8lbs.
http://www.boosted-hybrid.com/dyno_video.html
That graph was his last run, 15 total dyno runs. The engine was heat soaked. We could easily make 310whp with a 3" dp and 3" exhaust. This was on the 10.6:1 compression. Your friend needs a good tuner.
Old Apr 5, 2003 | 09:55 PM
1fstevo's Avatar
New User
Default Re: How safe?? Turbo R (boosted hybrid)
ah, good point, mustang dyno do under rated the power ( or it could be the other way around, dyno jet over rated the power).
Old Apr 5, 2003 | 10:01 PM
-=-'s Avatar
So its the tuning right. damn those tunners!.
Brings me to the point, when you take your car to the dyno to get it tunned, what all are they doing/changing?
hes also runnin hondata. if that helps. I wonder why those tunners didn't tune them right, the shop take most of their cars to that dyno place.
[Modified by -=-, 2:06 AM 4/6/2003]
Old Apr 5, 2003 | 10:15 PM
They alter fuel and timing.
Old Apr 5, 2003 | 10:36 PM
-=-'s Avatar
Hey how far are you from va.. 757 area specificy.. i might tell him to get your peeps to tune it =x.. millienum autosport(or whereever they took it to) did hes tuning. =x their like 10 min away from hes place. you know any places thats good at tuning thats not that far from va?(suffolk, portsmouth, va beach area)
Old Apr 5, 2003 | 10:38 PM
I am located in easton, pa. Pretty far from VA.
I would suggest Sgt to tune your car. He is in your area, and is one of the best hondata tuners in the country. Pm him: Sgt
Old Apr 5, 2003 | 10:39 PM
1fstevo's Avatar
New User
They are probably on the safe side by running rich or retarding excessive timing. Just protecting themselves. I run alot of timing but then again, I tune it myself so if it did blow, it's on me. I like to run alittle more than safe timing.
Old Apr 5, 2003 | 11:04 PM
hybridb18's Avatar
i know this guy with a 2000 type r with a turbo and stock motor, it ran a 12.60, it was fast till he blew it up
Old Apr 5, 2003 | 11:08 PM
-=-'s Avatar
Default Re: How safe?? Turbo R (hybridb18)
ouch.. how long did it last? how much power/ pounds of boost did he mess wit.
Old Apr 6, 2003 | 01:08 AM
MiraiZ's Avatar
tuning is the key
Old Apr 6, 2003 | 06:09 AM
TurBoXBirD16's Avatar
Default Re: How safe?? Turbo R (MiraiZ)
tuning is the key
word!!
how's ur car going alone MiraiZ?? still breaking in??
oh.. so finally how did they route your oil return line into the block?? pics would be good
good luck
Old Apr 6, 2003 | 06:26 AM
MiraiZ's Avatar
Default Re: How safe?? Turbo R (TurBoXBirD16)
tuning is the key
word!!
good luck
they redid it to the pan...the block turned out to be too high....
but its going really well still breaking in but I already feel a noticeble torque boost at only 0.1 bar ...1 bar is going to be insane!!
[Modified by MiraiZ, 12:27 AM 4/7/2003]
Pellegrini808
Aug 30, 2013 10:10 PM
juanintec
Jul 10, 2008 10:14 PM
DC4R27
Oct 6, 2007 07:34 PM
seanclark
Jun 13, 2006 02:52 PM
riceburnah
Nov 22, 2004 12:49 PM
