Balancing an Engine
Old Apr 4, 2003 | 06:22 PM
ludesleep's Avatar
Default Balancing an Engine
Should you always have your crank, flywheel, underdrive pulley, rods,pistons ect.. balance after a rebuild? About how much should i expect? just so i dont get ripped off. I was told by a very smart mech who mainly builds vett engines that most after market parts such as crower come very close and dont need balancing. What are your opinions, help me out im trying to learn haha
Old Apr 4, 2003 | 06:32 PM
niedejb's Avatar
Default Re: Balancing an Engine (ludesleep)
I paid $120 to balance mine.
Regardless of how close they come, I would still have it done.
Old Apr 4, 2003 | 06:48 PM
ludesleep's Avatar
Default Re: Balancing an Engine (niedejb)
and does anyone know the process of blueprinting an engine? Is it pretty costly. Sorry i know i should search this stuff but you know whats up on the seach prob. but Im about to take my engine in and have everything done so I was just curious
Old Apr 4, 2003 | 07:10 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
blueprinting is sort of a myth lately in the honda world. a builder will set a tolerance to which to comply with, usually much less than factory, such as bearing clearances, piston to cylinder clearance, etc. as well as weight of components. it requires of carefull consideration of differences, sometimes involving purchasing of the same part over and over untill it meets the tolelrance requirements. abolutely not worth on a street motor, unless you have cash to burn and a builder that knows his/her stuff. balancing is more than enough for a nice, happy street motor.
all that said, my first Zcar had bluepriting done at topend back in the day.
stan
edit and spelling owns me
[Modified by 90crxsi, 8:12 PM 4/4/2003]
Old Apr 4, 2003 | 07:40 PM
ludesleep's Avatar
Default Re: Balancing an Engine (90crxsi)
see i heard this too...i was told that if someone said the engine was blueprinted that it was prob. full of ****. Cause it cost so much money..but some people i guess can afford it
Old Apr 5, 2003 | 08:15 AM
E Swift's Avatar
I can afford it, therefore I had both procedures done on my motor.
Old Apr 5, 2003 | 08:31 AM
ludesleep's Avatar
Default Re: Balancing an Engine (E Swift)
how much did the blueprint cost?
Old Apr 5, 2003 | 11:44 AM
Aeka GSR's Avatar
New User
Is it necessary at all? I'm getting new sleeves pistons and rods.
Should I send in my crank, flywheel, and pressure plate? Should I bring in the pistons and rods also?
What is the usual wait time from drop off to pickup? Do I do this at any regular machine shop?
[Modified by Aeka GSR, 1:03 PM 4/5/2003]
raverx3m
Jan 15, 2015 06:10 PM
genuser
K Series
Jan 7, 2015 09:22 AM
bonesx0x2x4x
11
Apr 13, 2012 11:35 PM
Elwuudz
11
May 28, 2008 02:40 PM
Bulli Kid
Honda Civic (2006 - 2015)
17
Dec 4, 2007 02:24 PM
