Fuel Pressure regulator problem
Old Apr 6, 2003 | 05:36 PM
420aNT's Avatar
Default Fuel Pressure regulator problem
I have a remote fuel pressure regulator and I am not sure how to hook up the stock rubber return line to it. I used all braided line for the feed lines but I see no way to hook up the return. Am I missing something here? Also it has 2 fuel inputs and 1 needs to be plugged. What should I use to plug it? Can I use a 6-an plug or do I need to use a rubber o-ring with it?
Old Apr 6, 2003 | 11:56 PM
Flamenco-T's Avatar
Default Re: Fuel Pressure regulator problem (18gTeg)
it'll help to know what kind of FPR you have...
most paxton or SXR or aeromotive has -10 inlets and -8 return.
Old Apr 7, 2003 | 01:35 AM
accordfreak's Avatar
Default Re: Fuel Pressure regulator problem (Flamenco-T)
return line on my FPR is -6an stock is -4an.
i used a reducer from -6 to -4 then bought a -4 super stock hose end for the stock rubber line.
[Modified by accordfreak, 10:38 AM 4/7/2003]
Old Apr 7, 2003 | 07:50 AM
420aNT's Avatar
Default Re: Fuel Pressure regulator problem (accordfreak)
excellent thats exactly what I needed to know. My FPR has all 6-an fittings. So I will just do the 6-an to 4-an rubber hose like you did. Thanks for your help
jdm_h22
Jan 7, 2016 05:58 AM
Charlie Moua
Mar 22, 2013 05:17 PM
B16B_coupe
Jul 10, 2006 06:29 PM
hybrid_vtec
Aug 27, 2004 10:02 AM
baphomet
Oct 7, 2003 10:08 PM
