Car turns off even when timer is set
Old Apr 6, 2003 | 09:08 PM
incognitoracerr's Avatar
Default Car turns off even when timer is set
Guys....i have the turbo timer set for 2 1/2 minutes and for some reason the car stays on like its supposed to when it wants with the 2 1/2 countdown then it shuts off like its supposed to be then like every other time when i take the key out it doesn't want to stay on....it stays on when it wants and shuts off when it wants;.....this darn thing is supposed to keep the car running every time and not shut off the engine until the countdown is over....the wiring is correct...what do you guys think it could be besides the wiring?
Old Apr 6, 2003 | 09:17 PM
Mase's Avatar
Default Re: Car turns off even when timer is set (incognitoracerr)
are you sure the wiring is correct?
Old Apr 6, 2003 | 10:51 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
check and make sure the handbrake connection is good. i had this problem and it was a loose connection at this wire. so i guess only check if the car shuts when you let the handbrake down.
[Modified by not so civic, 7:52 AM 4/7/2003]
Old Apr 7, 2003 | 02:38 AM
niedejb's Avatar
Default Re: Car turns off even when timer is set (not so civic)
What brand of timer? I had the pencil sized apexi one and it did that to me.
Changed to the Greddy timer I have now (with no wiring changes) and it works 100% of the time.
Old Apr 7, 2003 | 07:31 AM
FORCED FED TEG's Avatar
New User
Try the brown wire that goes to the hand brake. If that don't work maybe you can swing by my house and we can plug in my timmer in your car to see if you have a bad timmer.
Old Apr 7, 2003 | 07:58 AM
Default Re: Car turns off even when timer is set (FORCED FED TEG)
Sorry guys...lol...it was a wire..it was the wire to the brake...i noticed i did not give the wire enough play so every time i pulled the brake the wire was disconnecting....got it to work....thanks a lot
Old Apr 7, 2003 | 08:23 AM
BstnLsVtec's Avatar
yah thats a good idea check the hand brake connection. i had the same problem with mine
Old Apr 7, 2003 | 03:34 PM
glad you found the prob.
DruWO
Nov 22, 2004 08:23 PM
incognitoracerr
Apr 6, 2003 09:19 PM
Shaun K
Apr 17, 2002 07:53 PM
GruvyTune
Oct 29, 2001 01:20 PM
