overtightened BOV...
Old Apr 6, 2003 | 11:33 PM
mitsuman's Avatar
Default overtightened BOV...
well me and my friend where "tuning" his greddy type-s bov on his 99 eclipse. and i think he tightened it a bit to much. cuz i went to loosen it and it got loose right away instead of loosining gradually like normal bolts would when tightened down hard. what happened? can it be fixed? has this happened to any body else?
Old Apr 6, 2003 | 11:42 PM
ninesecrx's Avatar
Default Re: overtightened BOV... (mitsuman)
Sounds like maybe he striped the threads out?
Old Apr 6, 2003 | 11:45 PM
mitsuman's Avatar
Default Re: overtightened BOV... (ninesecrx)
threads look fine
Old Apr 7, 2003 | 12:40 AM
mitsuman's Avatar
anybody?
Old Apr 7, 2003 | 06:31 AM
T3T495GSR's Avatar
why do people tighten or loosen that screw anyway? does it make it louder ?
Old Apr 7, 2003 | 07:10 AM
swrdply400mrelay's Avatar
Default Re: overtightened BOV... (T3T495GSR)
You want to tighten it so it doesn't leak any pressure, but not too tight where you still have compressor surge.
Old Apr 7, 2003 | 10:53 PM
mitsuman's Avatar
Default Re: overtightened BOV... (swrdply400mrelay)
im talking about tightening the screw on top so its harder/softer. as in how it will sound. i tightened it a bit to tight. and wont go all the way back where it was when it was loose, the bolt will go loose but it goes loose right away like this...
|| = screw on top of bov
---- = bolt
original "loose position"
new "loose position"
shouldnt it go back? can this be fixed? plz help
[Modified by mitsuman, 11:53 PM 4/7/2003]
[Modified by mitsuman, 11:54 PM 4/7/2003]
Old Apr 8, 2003 | 09:07 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I don't understand the picture at all.
All I know, is on my Blitz BOV, I went to check the screw, and it came off pretty quick. I just gave it one full turn of tightness.
Old Apr 8, 2003 | 10:49 AM
mitsuman's Avatar
Default Re: overtightened BOV... (Snafu-Si)
|| thats the screw on top of the bov.
---- picture that as the bolt that spins around the scre
|| thats thew bolt 1/3 of the way down the screw.
anybody alse?
leinadmiih00
Feb 5, 2007 10:03 PM
99delsol
Sep 19, 2006 05:14 PM
graphic
Sep 17, 2003 08:23 PM
buh_buh
Mar 22, 2003 05:19 PM
FBP Si 2000
Feb 7, 2002 07:21 AM
