gauge bezels?
Old Apr 6, 2003 | 01:43 PM
DawgPoUnd's Avatar
Default gauge bezels?
anyone use a gauge bezel? if thats wat its called the gauegs that go by the speed/gas..etc
i drive a 1999 civic ex (acura 1.6 el)
i wanna use the bezel instead of the pod........just need to know if theres a standard size of gauge that fits in them? and wat that seize is
also hows the fit on them? and if they blcok anything
i wanna put a boost and egt gaueg there
Old Apr 6, 2003 | 02:06 PM
ModlesSI's Avatar
New User
Default Re: gauge bezels? (DawgPoUnd)
Hrm, kinda hard to understand.. but the gauge bezel fits 52mm gauges... but they can be modified to fit 60mm gauges.
They look alright.. kinda cheap compared to OEM. If you do get the bezel, go w/ Autometer instead of Tsunami, b/c Tsunami blocks alot of the stock tach and temp gauges.
Old Apr 6, 2003 | 02:42 PM
DawgPoUnd's Avatar
Default Re: gauge bezels? (ModlesSI)
how much cheaper is the quality
for the boost i want one of these gauges
http://216.82.69.117/detail.asp?PRODUCT_ID=GR-8002
http://superhightechnology.com/prodd...invID=RG-2TB-B
i have the A/C tack gauges.not bad.but i like the superhigh boost gauge better
not sure how good they are......are boost gauges basically the same.or are the better brands better
just running 6 psi
wat gauges do u guys reccomend.i want boost/egt........is that good or should i get a/f or oil pressure or somthing.....i want 2-3 gauges thas it
Old Apr 6, 2003 | 03:49 PM
Racerage1's Avatar
i have the AC boost gauge(dont flame, it was free and i am low on funds)
its accurate, i guess, but i have nothing to compare it to...it reads 5.5, which is what i should be running so its ok i guess... if i were u, and i had the money i would just invest in apex,hks or greddy gauges(thats what im planning)
Old Apr 6, 2003 | 04:10 PM
DawgPoUnd's Avatar
Default Re: gauge bezels? (Racerage1)
i dont have the money though
i have buy a boost/egt gauge for sure
and AF or oil/water pressure gauge..........not sure if i need the oil/water pressure
which is more important the AF or oilwater pressure gauge
wat u think of this gauge
for egt imma prolly get a apexi or greddy or sumthin
and if i go with AF it iwll be atometer
if i go with oil/water pressure it will be blitz
Old Apr 6, 2003 | 06:19 PM
Infinity_Racer's Avatar
well the A/F gauge is not accurate at all unless you're running REALLY rich or REALLY lean, and then it wont move at all...other than that, all it does is blink back and forth...just save up for a wideband o2 sensor and use that to monitor your A/F...
duh blacksheep
Aug 3, 2004 01:42 PM
HONDA-2NR
Mar 6, 2004 10:54 PM
jdm jedi
Oct 4, 2002 06:40 PM
Muglit
Apr 4, 2002 01:15 PM
808eg6
Feb 17, 2002 03:32 PM
