LS jrsc install questions
Old Apr 6, 2003 | 09:22 PM
B_1_8_hatch's Avatar
Default LS jrsc install questions
i just recently installed my jrsc on my ls motor and i have some questions about it.
i got some instructions, but they suck and don't have any pics. the black thing that is on the back on the manifold (i think the boost pressure deal), where does the line go to on the manifold?
do i need to use the fmu or can i run the fuel line straight to the fuel pressure regulator instead of running it to the fmu and then to fpr? how do you adjust the fmu also?
is there a cai intake that i can buy that will fit with the jrsc? i can't use my current cai because it doesn't fit anymore.
i have a 98 ls motor and there is a purge sensor deal on top on the manifold. how do i hook this up with the new supercharger cause it doesn't have a hold on the manifold to put this sensor back in. the sensor has a little pipe deal that would stick into the manifold to suck in air and and a hose on the sensor that went to the canister i believe.
i'm only running 6 psi right now, will i be okay with my stock fuel pump, or should i get a walbro 255 fuel pump?
i think that is all the questions i have for now. the car runs good and idles at 1000, i just want to make sure i have everything right. it seems like i do, but i have some small doubts about the questions i have asked above.
Old Apr 7, 2003 | 08:38 AM
Muad'Dib's Avatar
Corr Performance Pilot
Default Re: LS jrsc install questions (93hb)
go here. under the HOW TO section.. they have a picture install of a JRSC. http://www.c-speedracing.com. HTH.
Old Apr 8, 2003 | 11:33 AM
96IntegraRS's Avatar
Don't understand - do you mean the pressure switch??? It's an electrical switch...
Get a B&M gauge and set it to 52PSI. You adjust pressure by turning the allen screw on the side of the FMU.
Cut your CAI or buy a DC short ram.
Read the instructions again; the answer is there.
Buy a new pump. Stock can't keep up. 52PSI base X 5:1 Rise X 6Psi boost = 82Psi. The big Walbro is good to 100+.
You are at a point where you could break things. Get some tuning assistance.
Old Apr 8, 2003 | 02:19 PM
Default Re: LS jrsc install questions (96IntegraRS)
okay, everything is hooked up correctly. all lines and sensors were right. so the only thing i need now is the fuel pump right? i'm only running 6psi and somebody told me i was alright using my stock fuel pump, what do you think, get the walbro 255 fuel pump?
thanks
Old Apr 8, 2003 | 02:41 PM
Sonny's Avatar
Do NOT run the stock pump.
Sonny
Old Apr 8, 2003 | 05:04 PM
Default Re: LS jrsc install questions (Sonny)
i ordered my fuel pump. it will be here thursday cause i got overnight shipment. they will ship it out tomorrow. i got it from the best buy section. $104 shipped to my door overnight. thats a good price to me.
what do you guys think about the jr thermostat they have? its like $10.
johnnymass
Mar 22, 2011 01:45 PM
escape2me
Sep 21, 2005 08:12 PM
JRciv
Dec 12, 2004 04:43 PM
RacerXI
Feb 15, 2003 11:38 PM
